![]() | Home > Technical (L322) > 08 TDV 3.6 Vogue BATTERY |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
My MY08 TDV8 has had 2 batteries in the last 4 years. The most recent episode was a few weeks ago and even using a CTX battery charger wouldn't charge it enough to start the car more than once. My pattern of usage hasn't helped, as I'm away for long periods of time and use the car only at weekends, only for shortish journeys.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I have same battery, my is original to the car so going on to 6 years old and still holding very well. you can look up date of the battery on the negative post, on top. first two numbers are weeks and other two year. my is 34 (mid september) 2011.
goopta Member Since: 04 Jul 2014 Location: Aberdeenshire Posts: 14 ![]() ![]() |
What I did was jump start the battery with a Fiat 500 I also own. Connected it up and left it running for 15 min and the range rover started first time. Left this running for an hour and a half then put the battery charger on it. The voltage in the battery after running it was enough to allow the charger to go through it's checks and then charge the battery. |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
When I replaced the useless Bosch S5 in mine with an AGM battery ALL my battery woes went away.
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 ![]() ![]() |
Nick, which AGM battery did you use?
Varta G14 is OEM on my. |
Land Rover quoted me £175 for an AGM and they said it was 95AH and 850 cold crank, which sounds a little low compared with many non AGMs people use.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
I fitted a ABS 020 XD+ , 120 ah and 950 cca to my 2007 VSE a good while ago , was very cheap and all been good so far. 2015 4.4 AB
Wow, they are a good price. £90.
I will check but its over a year now and it came with a 5 year warranty. 2015 4.4 AB
Just checked using the 'my posts' function and it was Mar 16 2015 4.4 AB
Cheers.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
As much as i don't like stealer's a few indys i know and Craig said get a JLR one as others can cause issues had it two years and was just over £200 and still runs like a new one 30k miles on |
I would advise following someone like Craigs advice but maybe find out who makes the batteries for jlr becuase they obviously dont manufacturer the batteries themselves. 2015 4.4 AB
