Home > Technical (L322) > 08 TDV 3.6 Vogue BATTERY |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Got to say that AGM was only ever fitted to the last of the ffrr's 2010_2012, all the rest had either an 019 or 020...
10th Dec 2017 4:06pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Bluegreygreen Rangie, this is pic. of my on IIDTool
11th Dec 2017 8:17am |
Bluegreygreen Rangie Member Since: 10 Aug 2012 Location: Australia Posts: 53 |
Cheers... But it does not say AGM anywhere?, Are you assuming hd means agm?, 2010 TDV8 Autobiography
11th Dec 2017 12:06pm |
BBGR, it is the original battery to the car, so , yes I asume that H8HD means AGM.
11th Dec 2017 12:47pm |
austeve01 Member Since: 17 May 2015 Location: Flagstone, Qld Posts: 12 |
I had a somewhat similar issue with my RRTDV8 (08 Luxury 3.6). Battery was 18 months old when it failed to start. Can't remember what the warning was but I had the battery & alternator checked by Royal Auto Club (Qld) and Battery World (retail supplier) .. both saying the alternator was testing OK but but the battery was just in need of a charge. The battery was regularly charged every month overnight on a Ctek (7amp). I did as advised and charged the battery again. It was OK for a couple of days but then wouldn't start the car.
13th Dec 2017 1:35pm |
Thank's buddy... Yes i guess that makes sense, These are the things people like Gap diag should be doing and putting down in some actual literature so that there products were actually of some use ... unfortunately as good as these diag companies are they are always half assed and semi professional at best 2010 TDV8 Autobiography Past - 02 & 03 TD6 And an 1984 Classic GAP Diagnostics |
14th Dec 2017 3:00am |
