Home > Maintenance & Mods (L322) > Bit of help needed.
DavidB64
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Barolo Black
Bit of help needed.
Hi all,
New to Land Rover ownership and loving my MY12 L322 Westminster. Could the members help with a switch in the engine compartment.
I’ve found a black switch with vertical pin that located at the back of the engine compartment on the left hand side - it was taped down. Not sure what it’s controlling or what it’s meant to be in contact with.
Does anyone know what it’s for and should I retake it up so far there doesn’t appear to do anything! Which I know that can’t be true
Sorry if I’ve posted in the wrong area.
Thanks for the help guys
David
Post #452080 25th Sep 2017 6:39pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
bonnet open switch , linked to the alarm ??
Post #452082 25th Sep 2017 6:48pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
It could be the bonnet switch for the alarm.
If it is then it’s looking likely that the previous owner had a problem with the alarm and determined that this switch was at fault...
Not expensive at all to replace if it is..
Best of luck.
Simon ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #452084 25th Sep 2017 6:51pm
DavidB64
Thanks guys - thought it might be alarm related but haven’t had any false alarms or it going off at 2am. Will keeps weather eye out or should I say ears!
Post #452089 25th Sep 2017 7:14pm
Baltic Blue
Bonnet switch. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #452090 25th Sep 2017 7:19pm
DavidB64
Thanks Baltic looks like its the same but without the white lump on it Smile
Post #452112 25th Sep 2017 10:15pm
best we have a pic to look at David... ... - .- -.
Post #452125 26th Sep 2017 7:20am
DavidB64
Thanks Stan will do when I’m reunited with her just because n the big smoke for work this week D
Post #452128 26th Sep 2017 7:41am
DavidB64
My lad took a snap hope this helps
Post #452130 26th Sep 2017 8:07am
