Home > Technical (L322) > How-to: Start Stop Button Replacement
Page 1 of 3 123>
TTB
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
My 2010MY Vogue SE has a cracked start/stop button, my local dealer wanted £290 to replace it stating that it's an expensive switch and a dash-off job. So I did what any self-respecting forum member would do and googled the hell out of the subject. I couldn't find a how-to-guide so I thought I'd take some photos as I did the job to help anyone else looking to do this repair:
I found a new genuine switch with a slightly different part number that works for £19 (LRI Solutions): LR011898
The button is slightly different but it illuminates with the correct colour. Before:
After:
The button is held in with three clips which need to be depressed to release it from the dash panel. You can see them in the following photos, one in the centre of the bottom of the switch and the other two at 120`
I was worried about damaging the soft dash so I put a bit of masking tape around the old switch before using an electricians screw driver to pop the clips one by one starting with the bottom one:
The switch popped out easily and there is a good length of wire to allow you to test the new switch before pushing it back into place.
Took no more than 5 minutes so I feel like I just won £270. Very Happy
Hope this helps anyone else who's suffering from a cracked start/stop button
Simon
Post #451807 23rd Sep 2017 9:07am
thats great Simon i'll stick this in our wiki..
its known that these are easy to replace but a 'how to' is very handy ... ... - .- -.
Post #451809 23rd Sep 2017 9:17am
mpirie
Excellent "how-to" Bow down
By my calculations, the dealer is charging £3,460 per hour (12 x 5 minutes @ £290 less £20 for parts)
Of course, this rate is used to cover the majority of faults that should have been picked up at the factory QC Whistle
Mike
Post #451810 23rd Sep 2017 9:27am
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Really good write up TTB.
I had a cracked button for a while however have recently had starting issues and alot of the threads point to a cracked button causing it to malfunction? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #462380 27th Dec 2017 8:20pm
TTB
Hi Scotcruz,
The part number is LR011898. It cost less than 20 quid from LRI Solutions as "old stock" but they don't have any left. But if you Google for the part number you should find somewhere. LR Direct has them for under 40 quid:
https://www.lrdirect.com/LR011898-supplied...ROVER.html
Post #462381 27th Dec 2017 8:28pm
scotcruz
Cheers mate.. I was gonna say that you got a real bargain there..
cheers for the link.. gonna start looking for it now.. Current:
Past:
Post #462387 27th Dec 2017 9:51pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
excellent how to - highly recommended - £40 switch + 5 minutes
Post #479759 31st May 2018 9:39am
bertie1
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
I wonder if land rover customer relations will comment ???? Rolling Eyes
Post #479812 31st May 2018 5:05pm
roel2018
Belgium 2011 Range Rover Vogue SE TDV8 Santorini Black
Re: How-to: Start Stop Button Replacement
Hi there,
Mine is also damaged so I need to replace this part with number LR050802 but I have 2 questions:
1. Is there a difference between LHD or RHD?
2. Do i need to re-program this part because of keyless start?
3. Will this part also fit on a 2011 Vogue TDV8 4.4.?
[img]
Thanks!
Roel[/img]
Post #490552 1st Oct 2018 3:00pm
haaris
Ireland 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Should this button light up fully. only ENGINE and STOP light up. Not the START
Post #516228 22nd May 2019 8:27pm
haaris
Post #516229 22nd May 2019 8:29pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
That has always annoyed me! But yes, only engine and stop. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #516344 23rd May 2019 4:27pm
roel2018
Ignition start button LR050802 / late L322 models
Some extra information from my side after replacing:
Coding is not required for the facelift model TDV8 4.4. 2011. Just plug and play 5 minutes. Here is a photo from the connector when the cables are disconnected
Post #516670 27th May 2019 2:02pm
leusfx
Would you know how upgrade to start/stop button on FFRR TDV8 2008 when there is normal key fob?
Post #537058 11th Dec 2019 3:37pm
mike73
Canada 2008 Range Rover Supercharged 4.2 SC V8 Java Black
Sorry to hi jack this thread, i have a 2008 range rover and it has the keyed starter switch in the same locations, does it come out with the same method?
Post #558254 19th Jun 2020 1:11pm
Page 1 of 3 123>
