Home > Maintenance & Mods (L405) > L405 Fixed Side Steps |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Mine came with step by step instructions ( what a pun!) as to how to fit them and what needs cutting out. You have to remove the underside plastic protectors that run the length of each side of the car and cut out bits (marked on the plastic already if I remember) so as to fit the 4 step mounting brackets. I put my car in extended off road height (i.e. engine running, hazard flashers on, then use remote key fob to raise car higher than normal off road height, then engine off again) and put a couple of axle stands underneath it just for good measure. Bit cramped, but got it done ok , a pit or ramp would have been handy though Steve
22nd Sep 2017 1:51pm |
To put into extended off road...
23rd Sep 2017 11:21am |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
That’s a very great help, thank you! |
23rd Sep 2017 2:07pm |
