Home > Maintenance & Mods (L322) > Dashboard thinks it's Christmas
lawsey
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Saturday took the car for a 400 mile round trip. Sunday started first time but battery warning light stayed on, checked battery 13.75 v so alternator is charging. Took it for a short run and all sorts of lights began flashing Parking brake, ABS etc and display ran through fault programs No ABS, Parking brake fault, Transmission Fault, HDC inactive and many others that i didnt have time to note.
Monday checked battery volts. 12.68. not started. 13.8 when running but charging light still on.
Anyone any ideas?
Post #451301 18th Sep 2017 4:01pm
Most likely you need a new battery.
Do you know if it's ever been replaced? I'm on battery number 3. Got - 2017 SDV8 Autobiography in Loire Blue
Post #451306 18th Sep 2017 4:46pm
Sandyt
I change mine every two years regardless - have the battery tested but a new one is not a bad investment anyway
Post #451307 18th Sep 2017 4:50pm
lawsey
varta battery the big one fitted last November. 13.5volts coming from alternator. Charging light remains on.
Post #451316 18th Sep 2017 6:21pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
13.5 sounds low to me pal , id expect 13.8-14.2 with engine running
Post #451340 18th Sep 2017 8:10pm
Have the battery tested first.
The bad news is that the 2007 TDV8 seems to have an unusually high failure rate for alternators.
An example thread below, but there are others -
http://www.fullfatrr.com/forum/topic16178.html
Post #451359 19th Sep 2017 12:28am
bishbosh10
Yep, I agree with Bembo - alternator should be charging at at least 14V preferably more. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #451373 19th Sep 2017 7:10am
lawsey
Car on with the MD they suspect alternator failure. anyone ideas at likely costs. £110 per hour thought they would have a better idea than suspect??
Post #451421 19th Sep 2017 4:37pm
bembo449
I surprised you took it to an MD for that pal , rob dogs !
Post #451430 19th Sep 2017 6:35pm
Sandyt
New denzos are about 700 quid replaced mine on 4.2 supercharged the other week at ten years was ok but new one is belt and braces
Post #451431 19th Sep 2017 7:21pm
Shocking price really. A new alternator for an MG Midget is £60 and fitting time of no more than 20 minutes! .
Post #451437 19th Sep 2017 7:43pm
gizze
You can buy the Denso from ECP for around £210 by the way.
Local RR specialist said they can do it on the TDV8 in 2 hours now.
I replaced the water pump the other day and could have done the alternator after seeing it properly, so would agree 2 hours if they know what they are doing no problem.
He said £350+vat fitted for a new one.
Land Rover quoted me £550 for the unit plus 3 hours labour so was coming in around £800.
Have you done a test for parasitic drain?
I was told the alternator and battery had been changed by the last owner, I started to doubt it hence getting quotes.
Turns out my car was drawing 1.1amp when asleep, it was the Bluetooth module that was knackered, I had all the issues you describe, once that was removed it was sorted.
Where are you getting the 13.5v value from? The display screen or the battery terminals?
Mine often blips between 13.5 and occasionally 14v on the nav screen, but reads a good 14.3-14.5v on the battery terminals. Porsche 911 (996)
2015 BMW 5 Series Touring
Not got a LR of any kind at the mo, and got itchy feet.
Post #451447 19th Sep 2017 8:36pm
