Home > In Car Electronics (L322) > Ulf upgrade fitting amplifier
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I have low volume issue on my upgrade and want to fit an amplifier has anyone got a wiring diagram of where it goes in the system for best effect. Colour codes of wires involved would be good.
Post #450945 14th Sep 2017 9:03pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I also would be interested in info.for this
Post #451136 16th Sep 2017 8:54pm
wiki, denso.....in the 'info' section.. ... - .- -.
Post #451150 17th Sep 2017 5:15am
horsedentist
I have found a little Chinese amp that I think might do the trick waiting for it to be delivered will post an update if it works. I now know where to fit it so will let you know if it works.
Post #451189 17th Sep 2017 3:30pm
horsedentist
Chinese amp installed and works a treat sound now better than my parrot on the wife's jeep.
It was two channel so just connected one channel up and perfect bolted it under nav unit where the voice control used to be.
Whistle
Post #451781 22nd Sep 2017 7:49pm
Lukie
Could you let me know the parts you used, and the wiring diagram for it please could help alot of people on here
Post #451994 25th Sep 2017 7:59am
p38arover
Australia
Interesting. I have no shortage of volume on my conversion. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451998 25th Sep 2017 8:37am
Lukie
Ron ULF low volume I believe comes with the mk4 dvd satnav upgrade
Post #452117 25th Sep 2017 10:00pm
p38arover
Australia
Hi Luke, mine has the Mk 4 upgrade. Odd. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #452119 25th Sep 2017 10:31pm
horsedentist
I have the mk4 upgrade as well
Post #452134 26th Sep 2017 7:47am
Lukie
Can you share your findings with us so we can try and get sensible volumes on on bt
Post #452556 30th Sep 2017 5:28pm
horsedentist
Here you go guys here is how I solved mine been working a couple of weeks now with no problems.
The amp I found on eBay for 9 quid from jersey even cheaper from China just search 12v car amplifier.
The wiring is as follows cut the speaker wires by the ulf plug. Blue and black is speaker positive blue and brown negative.
Solder a length of wire with audio plug to the wires coming from the plug (audio leads come with the amp so I just cut a length off of one of them).
Connect a length of speaker wire to the remaining speaker wires leading to the car speakers. The amp has a jack plug input but a spring connector out put.
For a power supply I picked up the supply to the old voice unit at the jumper plug red and yellow positive and black and brown negative power lead also comes with amp.
Plug audio plug into left or right channel socket connect speaker wires to corresponding out put terminals.
Amp has mounting holes I enlarged one of them so I could use one of the old voice control mounting bolts to mount it under the nav unit.
I dialled up my customer service on phone and used the recorded message to adjust the volume turned it right down on steering wheel buttons then turned the amp up to a point where I could here it from back of car. Then you can adjust it on the steering wheel to your desired level.
I found I was picking up some interference on the set up so fitted ferrite rings on both speaker leads to the amp that stopped it.
Post #452618 1st Oct 2017 11:28am
horsedentist
The amp has an led display but it doesn�t keep the car awake have had no problems with mine.
Post #452619 1st Oct 2017 11:38am
