Home > In Car Electronics (L322) > Newbie problem touch screen |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 |
Hi mate I have been experiencing problems for last two weeks with my infotainment system I put it down to a battery disconnect also I have bypassed all relevant modules checked all fuses done hard reset no joy I have now resorted to buying a new head unit. These units are very temperamental and don't like battery disconnect or low voltage. What are you getting Land Rover screen or nothing? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
15th Sep 2017 12:17pm |
Have you checked all fuses the bluetooth was probably disconnected due to water leak common fault I had the same issue. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
15th Sep 2017 12:22pm |
Jason miller Member Since: 15 Sep 2017 Location: Luton Posts: 9 |
Hello yes all fuses relays wiring. I have power to the head unit, amp, and radio control unit. The screen just does not come on not even the orange light. |
15th Sep 2017 1:18pm |
Am going to buy another head unit today and see what happens. |
15th Sep 2017 1:20pm |
Yes best option as it can only be a defective head unit and after all they are over 10 years old plus if you look about on fleabay you can pick up 2008 model for about £200. Instead of the £2500 price tag of a brand new one😂😂 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
15th Sep 2017 3:44pm |
Well we tried two head units and nothing. The only thing left is to put it on the laptop and see if there is anything there. |
15th Sep 2017 7:04pm |
That's bizarre I fitted mine this evening and all good I had a faulty touch screen head unit after 2 weeks of testing everything it turned out to be this. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
15th Sep 2017 8:35pm |
Hello did you disconnect the battery and let it power down. Or just plug it in. |
15th Sep 2017 8:38pm |
Sorry I will put it a bit better. How did you fit your new one. Did you let it power down and then disconnect the battery, or just plug it in. |
15th Sep 2017 8:40pm |
No I never disconnected battery I just connected all the wires and pressed the power on button mate it's really strange you got no power going to the head unit it could only be one thing a blown fuse! Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
15th Sep 2017 9:17pm |
I have power to the head unit and the radio unit and amp but still nothing. There is no red light coming out of the fibre optic. I think the ecu maybe in safe mode. I just have to get on the computer now and see what's going on. |
15th Sep 2017 9:26pm |
How you getting on mate never heard of ecu safe mode to be honest there should be light out of the fibre optic cable if there is power present. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
16th Sep 2017 10:01am |
The car is asleep I need to find way of waking it up. Any ideas. |
16th Sep 2017 12:00pm |
Well just an update on my radio problem. It's fixed, it was the radio receiver box behind the main screen that went faulty. Radio all up and work now, including the most system. |
20th Sep 2017 8:05pm |
