Home > Technical (L405) > Rear Tailgate Area Squeak
DangerMouseUK
United Kingdom 2017 Range Rover Autobiography SDV8 Farallon Black
Hi Guys,
As per title, sometimes when the car gets a bit dirty (this might just be coincidental) - there's some sort of tailgate squeak type of noise either coming from the tailgate itself or the very rear of the roof area back in that zone.
Does anyone have any ideas or had anything similar from the back of the corner - its only when the suspension gets agitated and the car goes up and down - then I get a squeak from that area - over a flat surface nothing at all.
Hope you're well and thanks.
Post #450875 13th Sep 2017 10:10pm
DangerMouseUK
Seems to be slightly worse or more pronounced when the rear end area is wet or its been raining . . .
Post #450937 14th Sep 2017 8:59pm
CS
See thread in 405 'Maintenance & Modifications' re tailgate rubbing on D pillars, could it be that? Only Range Rovers since 1988
Post #450996 15th Sep 2017 12:43pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I'd guess it's the plastic panelling on the inside rubbing against the tailgate - should have adhesive rubbing strips / foam at various locations to mitigate this, also worth checking all the panel clips are pressed home fully / present (esp. if its been removed previously for some reason).
Post #450998 15th Sep 2017 12:51pm
DangerMouseUK
Going to check both - thanks guys !!
Post #451063 16th Sep 2017 2:08am
