![]() | Home > Technical (L405) > Rear Tailgate Area Squeak |
DangerMouseUK Member Since: 03 May 2015 Location: London Posts: 69 ![]() ![]() ![]() |
Seems to be slightly worse or more pronounced when the rear end area is wet or its been raining . . . |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
See thread in 405 'Maintenance & Modifications' re tailgate rubbing on D pillars, could it be that? Only Range Rovers since 1988 |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 877 ![]() ![]() ![]() |
I'd guess it's the plastic panelling on the inside rubbing against the tailgate - should have adhesive rubbing strips / foam at various locations to mitigate this, also worth checking all the panel clips are pressed home fully / present (esp. if its been removed previously for some reason). |
Going to check both - thanks guys !! |
