Home > Maintenance & Mods (L322) > Mysterious coolant loss...... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
Get the head gasket tested to eliminate that. |
19th Aug 2017 11:39pm |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 |
These cars can loose coolant from several areas without it dripping on the ground. EGR coolers can leak back into the exhaust, thermostat housing can crack and leak into the V and evaporate. Then as suggested above the head gaskets can go
20th Aug 2017 7:07am |
RJD Member Since: 31 Aug 2017 Location: Upington Posts: 1 |
Hi
31st Aug 2017 10:32am |
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 138 |
Cheers for all the info, it's definitely the air con dripping underneath. Heater works fine and carpets are dry
13th Sep 2017 6:10am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
You can get a coolant sniffer test kit for not much money. Plenty on Amazon and easy to use! Previous cars:
13th Sep 2017 9:31am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2265 |
Pressure test the coolant system |
13th Sep 2017 8:03pm |
Also the expansion tank and cap are known to fail after about 10 yrs the tanks crack and also the cap can lose its pressure capability
13th Sep 2017 8:11pm |
So...checked everything I could see without any luck, then today big pool of coolant under the car traced it to the passengers side just behind the fuel filter, looks like it's coming from behind a heat shield, everything was hot so I've not looked any further. Is there a parts cat that would show what's lurking behind the heat shield?
4th Oct 2017 4:46pm |
Found it! Temperature control valve (no looks favourite
4th Oct 2017 10:08pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Mine had a very similar leak, rhs of radiatior, little hose about half way up, rubber around the clamp had perished, cut half an inch off, reclamped anc all was good
4th Oct 2017 10:23pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
Think mine is leaking somewhere around the expansion tank. Is that common? Dan
9th Jan 2018 3:29pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1534 |
Dan, so was mine when I bought it. It took a while to find it. It was the expansion tank/reservoir. The tank had a 200kPa cap, not the correct 140kPa cap. (Look at the number on the underside of the cap.) Ron B. VK2OTC
9th Jan 2018 8:35pm |
Will do mate thanks, however it's only just started doing it and I've had it a few years now so guessing it's not the lid.
10th Jan 2018 10:16am |
Just checked and it is a 200 cap. So is that wrong for a 4.4l petrol as it's a bit strange is only just started blowing out after 3 years of owning it? Dan
13th Jan 2018 3:19pm |
