Home > Technical (L322) > 2004 Sat Nav Question |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35454 |
this is what makes me wonder if it is a cd based unit, worth a try.. |
7th Jan 2011 10:41am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1746 |
I'll give it a go but it does say DVD on the front of it. Just wondered if there is a certain range of part numbers that aren't compatible with RR? Ash
7th Jan 2011 10:44am |
ahh ok, if it says dvd then it should work with a dvd...it was just a shot in the dark... |
7th Jan 2011 10:50am |
AFAIK all MKIV's are compatible. Getting the unit to read the discs is not always easy - especially if the laser is on it's way out (always a risk on ebay units...). Laser replacement is not too bad though - DIY is under €50 if you're handy with tools and a soldering iron, replacement costs around €130 over here.
7th Jan 2011 11:06am |
Thanks Mate - Just tried an original working DVD from an 05 RR in the workshop. Same message so me thinks, unless there are certain non compatible units, the DVD drive or lens is knackered.
7th Jan 2011 11:10am |
Update..
9th Jan 2011 4:38pm |
I'd still guess: laser dying, not quite dead...
9th Jan 2011 4:51pm |
I had the french dash display when I had used a dodgey map disc. In the settings for Voice to do you have GB GB? In mine I think it was GB and blank. Do you have NavCoder? I had to use NC to downgrade the FW I think. Although my memory is a bit sketchy from a year or so ago.
9th Jan 2011 6:53pm |
