![]() | Home > Technical (L322) > L322 Reality Check, Any advice? |
Mr.plow Member Since: 03 Sep 2017 Location: the middle Posts: 4 ![]() ![]() ![]() |
Hello Folks, I have recently purchased a 2007 TDV8 3.6 Vogue. I love it, First RR. Never owned anything with such comfort. In a moment of bursting confidence I went for it. It was well maintained by previous owners. Drove perfectly on test runs. Three weeks later front left shock has a leak! Replaced it. These things happen, move on. Now seems to have a slow coolant leak. Enthusiasm slowly leaving me. I'm hoping it's a leaky hose.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Unnecessary quote removed
Thank you for that. |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Congrats. Mine is a similar mileage and vintage. They are getting very affordable.a beautiful vehicle, but a little subject to aging. Here are some suggestions to help.
thanks for the tips. |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
Mt 56 plate TDV8 has now done 127k..113k when I bought it... changed the thermostat housing and pipes..one or the other had started to leak, had all the brake pipes replaced after one popped and had the rear shocks replaced as they had started to leak. All age related stuff really.
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
think you have to accept that cars , even well maintained ones will have thing in need of repair , it could have FSH but no one is going to replace a suspension bag if theres nothing wrong with it eh ? |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I have a 2007 on nearly 150k I have put 90 of them on it had it 4 years It has never let me down but I have over the years replaced front suspension both sides and upgraded pump at same time replaced the coolant expansion tank and cap as they do fail replaced the alternator all pulleys and water pump all bushes and front arms and track rod ends battery every two years = all as preventative maintenance service regularly changed gearbox oil every 30 to 40k and it runs like a dream and as I said it has never let me down
