![]() | Home > Technical (L405) > how does the car know when you need a service? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7993 ![]() ![]() ![]() |
Oops |
Yes - when I bought mine I was told that it checks the oil quality
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
It does check the oil quality and it's very likely to be contamination with diesel as a result of interrupted DPF regeneration cycles. In LR's technical bulletin's own words "continued running with diesel contaminated oil will cause engine failure". |
syl Member Since: 24 Jan 2017 Location: Somerset Posts: 30 ![]() |
See this
Jon S Member Since: 10 Aug 2016 Location: Exeter Posts: 32 ![]() ![]() |
Oil dilution sounds bad. How does it happen? Mine's a 2013 so does this service bulletin still apply? |
To see how widespread the problem is, Google this:
I'll be getting my first oil change done at 8,000 miles (about 3 months), or less and pay for an analysis of the used oil and see what they find. |
I don't know about the DPF but I presume it has. Ironic though as the service warning thing came up after a trip to Italy- certainly plenty of time for DPF regen to occur!. I guess it may have happened before though. I'll get it book in for an oil change ASAP
The service bulletin only seems to refer to the 3.0 engine - does the same thing apply to the 4.4 ?
I've just read to the second page and you're right it is only 3.0l models. I asked my local non franchised specialist and he seemed to think that he hadn't heard of this being a problem in the V8s. I don't know if this is reassuring enough for me to ignore it / get the garage to rest it for the time being or maybe I should ask them to take out a sample of oil for testing.
Had my oil done at my Indy today - £120
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
The BMW diesel engines sense the oil life by means of an optical sensor which the oil passes over ... the dirtier it is, the darker it is ... till the point it thinks it needs changed.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
Mine was serviced last week and the service indicator still shows in needs a service. I queried this with the dealer as the list of tasks has a tick against the box for service indicator reset.
just an update- my non franchised specialist plugged in his computer and told me that it looks like he forgot to re-set the service indicator properly- apparently you need to re-set it for oil and service rather than a single reset as on all other models. He apologised and I hope he's right (bit paranoid about the contamination thing now but this seems to only be in V6s) |
