Home > Technical (L405) > how does the car know when you need a service?
Jon S
Does anyone know what precipitates the car to tell you that a service is needed. I had mine done only 5000 miles ago (6months) and it seems to think it needs another one. I think it's just being greedy as I don't drive it hard and although I tow occasionally I haven't done more than 1000 miles towing a small caravan and that was mostly on motorways. Does it check the oil quality somehow?
Thanks
Jon
Post #450059 6th Sep 2017 4:13pm
Oops
Post #450080 6th Sep 2017 6:05pm
Yes - when I bought mine I was told that it checks the oil quality
I've not had mine complain so far, bUt have done the changes slightly early as I regularly do 1500+ mile trips and Sod's law says it will complain 50 miles into one.
However, I also gave up MD servicing, so an oil change doen]sent cost silly money either Whistle
Post #450084 6th Sep 2017 6:08pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
It does check the oil quality and it's very likely to be contamination with diesel as a result of interrupted DPF regeneration cycles. In LR's technical bulletin's own words "continued running with diesel contaminated oil will cause engine failure".
Post #450107 6th Sep 2017 7:01pm
syl
See this
2017-07 JLRP00100 Service indicator message and oil dilution
Post #450113 6th Sep 2017 7:42pm
Jon S
Oil dilution sounds bad. How does it happen? Mine's a 2013 so does this service bulletin still apply?
Post #450128 6th Sep 2017 9:05pm
Red Merle
To see how widespread the problem is, Google this:
dpf regeneration oil level rising
To summarise, to unblock a partially blocked DPF, where you might not regurlay drive at high enough speed often enough, your car will go into active regeneration. This does anumber of things, but it includes injecting a lot more diesel during the process. If the engine is stopped before completion, excess diesel will seep down past the piston rings and into the oil where, after a while, it wrecks the oil.
As you can see from Google, it's not just LR.
Does your 2013 car have a DPF?
Post #450140 7th Sep 2017 5:07am
Red Merle
I'll be getting my first oil change done at 8,000 miles (about 3 months), or less and pay for an analysis of the used oil and see what they find.
Post #450147 7th Sep 2017 6:34am
Jon S
I don't know about the DPF but I presume it has. Ironic though as the service warning thing came up after a trip to Italy- certainly plenty of time for DPF regen to occur!. I guess it may have happened before though. I'll get it book in for an oil change ASAP
Thanks for all your help
Post #450153 7th Sep 2017 7:05am
The service bulletin only seems to refer to the 3.0 engine - does the same thing apply to the 4.4 ?
I ensure mine has a regular Italian tune up - which seems to work for me Whistle
Post #450161 7th Sep 2017 7:38am
Jon S
I've just read to the second page and you're right it is only 3.0l models. I asked my local non franchised specialist and he seemed to think that he hadn't heard of this being a problem in the V8s. I don't know if this is reassuring enough for me to ignore it / get the garage to rest it for the time being or maybe I should ask them to take out a sample of oil for testing.
I'll wait till I can get it to the garage (not using the car at the moment so not a big hurry). I'll post again when I have any further info.
Post #450179 7th Sep 2017 11:38am
Had my oil done at my Indy today - £120
Even if you want to keep a MD history intact, personally, I'd just get an interim change done by an Indy - kind of off the record - IMHO, for that money, it's not worth the stress.....
Post #450180 7th Sep 2017 11:46am
fisha
The BMW diesel engines sense the oil life by means of an optical sensor which the oil passes over ... the dirtier it is, the darker it is ... till the point it thinks it needs changed.
I would imagine the LR engines use a similar method to sense the oil quality. That combined with factoring based on mileage, how hard driven etc etc. V8 or else ...
Post #451044 15th Sep 2017 8:28pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Mine was serviced last week and the service indicator still shows in needs a service. I queried this with the dealer as the list of tasks has a tick against the box for service indicator reset.
Turns out there is a software problem and the dealer can't reset the service indicator until LR sort out the software. Also the Service needed message is not showing on start up as described in the bulletin above. Apparently they can't fix this either.
With my problem with the InControl app no longer working ( see another thread) I am beginning to think that LRs ambitions with software are running ahead of their capability.
Post #451465 20th Sep 2017 6:35am
Jon S
just an update- my non franchised specialist plugged in his computer and told me that it looks like he forgot to re-set the service indicator properly- apparently you need to re-set it for oil and service rather than a single reset as on all other models. He apologised and I hope he's right (bit paranoid about the contamination thing now but this seems to only be in V6s)
Post #452519 30th Sep 2017 9:33am
