Home > Technical (L322) > Air Suspension Inactive |
First of all welcome.
6th Jan 2011 7:15pm |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Hi i had this problem lots of time and it drove me mad you really need a diagnostic tool to read fault code and reset they are not too much but worth it with other issues when you have the code i can advise remmidy
6th Jan 2011 7:16pm |
S2WFR Member Since: 06 Jan 2011 Location: Shropshire Posts: 5 |
Hi Guys,
6th Jan 2011 7:38pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
right, the fault was there when you bought it, it was just reset and its taken a week to fault again.
6th Jan 2011 10:11pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1513 |
Also may be worth checking all the hoses between comp and collector. One becoming detached can cause it- also check the exhaust filter on the compressor- there are some pretty detailed threads on here about the filter.
6th Jan 2011 10:37pm |
yes they are the way forward but it looks like he has paid for this code already though?
6th Jan 2011 10:46pm |
Note that they use the EAS Unlock software - This is written by the same guy that sells the MKIII EAS Aktivate hardware. The software itself is free, Storey Wilson is an absolute star and I will pimp his wares any chance I get. It's unfortunate that this SW cant port over to the L322 from the P38. http://www.rswsolutions.com/index.php?opti...;Itemid=56 His Rover All-Comms Software will be the daddy though: http://www.rswsolutions.com/index.php?opti...;Itemid=18 Knowing him, it will be cheap and blow the competitors out of the water |
6th Jan 2011 10:54pm |
yea, any guy that takes these computer's on wheels and dissect's it gets my respect. Any rumors on forums of price? 2004 black Vogue TD6 |
6th Jan 2011 11:02pm |
Not as yet, I speak with him occasionally but he's been "tight lipped" for obv reasons. Personally I really look forward to software that enables me to mess with all the cars systems, especially if it allows me to change the settings for things. The other solutions on the market are too expensive and are locked to VIN, and whats the point if you cant help mates out with bugs... |
6th Jan 2011 11:21pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
My car has had this issue for near on 8 to 10 months. I simply lock it so it isn't always pumping up and down. Fault rarely occurs on short runs, but push it on the bends and off it goes again.
6th Jan 2011 11:36pm |
As was suggested, if the compressor is worn this problem would have shown for months. It sounds to me like you need to go back to the seller before throwing any money at the car... RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
7th Jan 2011 11:12am |
Hi,
7th Jan 2011 12:41pm |
The compressor doesnt directly drive the springs - it goes to a valve block, and generally from the reservoir first. If the springs are "getting too much air" it could be a sticky valve block - not unheard of. It could also be a failed/failing cross-link-valve. "too much air" isn't really relative to any code, Unless he's reading something like "RL + RR implausable height"? In which case that can also point to sensors. We need those codes! |
7th Jan 2011 12:56pm |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 |
Howdy
11th Jan 2011 12:56pm |
