Home > Technical (L322) > TDV8 alternator gone |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7957 |
Another 2007 TDV8 Alternator bites the dust - you're luck it lasted this long.....
30th Aug 2017 10:06am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Cheers Alastair
30th Aug 2017 10:15am |
Disconnect the alternator before you reconnect the battery. When they go dead short they will take out your wiring loom in seconds. |
30th Aug 2017 11:05am |
You are making me nervous now!
30th Aug 2017 11:20am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
A dead alternator in my experience will drain a fully charged battery in minutes. I did something similar. Recharged and drove it. But I didn't have any smoke. The alternator is on the driver side under the coolant tank. Have a look for a cable. ______________________________
30th Aug 2017 8:11pm |
As above, under the expansion tank. Large cable on the alternator, a thick one so it's easy to see. Remove this before reconnecting the battery. The thing is that when they go faulty they tend to tun into a 3 bar electric fire so they draw more current than the cable can handle and it all gets a bit warm.
31st Aug 2017 7:52am |
Thanks so much mate, will have a look later.
31st Aug 2017 8:18am |
Going to try to disconnect the alternator today,
2nd Sep 2017 7:27am |
Can anyone advise on what to do?
2nd Sep 2017 9:14am |
No question, I would disconnect the alternator. Yes it's awkward to get to but it is completely necessary if you want to avoid potential wiring damage. |
2nd Sep 2017 10:13am |
