Home > Technical (L322) > TDV8 alternator gone
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Sunday night, luckily at home, battery light comes on....Damn!!
Anyway trying to organise it going for repair at my mechanics place which is 50km away, charged the battery, and a spare, and I was going to chance driving it there.
Yesterday started the car, to shuffle about on our drive...smoke starts rising out from engine bay!
Switched off, still smoking..waited 3 minutes, and disconnected the battery, which I believe is now knackered.
Question: I am now trying to arrange transportation to my guys place, but I will still have to start the car to move to a position for collection, when I do this it will cause a short in the alternator again, will this cause any damage to anything else,
What are my options?
Post #449511 30th Aug 2017 9:59am
Another 2007 TDV8 Alternator bites the dust - you're luck it lasted this long.....
Basically what's happened is the diodes have gone - then it turns the alternator into a motor - but one that can't move, hence the smoke - and it will continue to try until your battery is flat.
Disconnect the battery - it may not be completely dead, recharge it - then connect it for the short time you need to move the car.
That's what I did when mine went - also used the recovery mans booster pack.
Post #449513 30th Aug 2017 10:06am
SFM
Cheers Alastair
I know it's done well, now on 90k!
Glad I was home when it went.
Just worried if it will damage anything else when reconnected.
All parts ordered ( original ) alternator £617!!! Plus 4 hours labour, my guy has done a few of these.
Post #449514 30th Aug 2017 10:15am
mzplcg
Disconnect the alternator before you reconnect the battery. When they go dead short they will take out your wiring loom in seconds. Thumbs Up
Post #449515 30th Aug 2017 11:05am
SFM
You are making me nervous now!
This is getting complicated...
How do I do that?
Post #449516 30th Aug 2017 11:20am
rar110
A dead alternator in my experience will drain a fully charged battery in minutes. I did something similar. Recharged and drove it. But I didn't have any smoke. The alternator is on the driver side under the coolant tank. Have a look for a cable. ______________________________
Post #449569 30th Aug 2017 8:11pm
mzplcg
As above, under the expansion tank. Large cable on the alternator, a thick one so it's easy to see. Remove this before reconnecting the battery. The thing is that when they go faulty they tend to tun into a 3 bar electric fire so they draw more current than the cable can handle and it all gets a bit warm.
There is a picture here, although this is for a TD6 it is largely the same. Top right of the page is what the back of the alternator looks like, just disconnect the wires shown by the arrows. EDIT: AND TAPE THEM UP BEFORE YOU RECONNECT THE BATTERY.
The upside is that once disconnected, as long as you have a fully charged battery you could drive it to the garage without issues.
You could also replace it yourself if you were so inclined. I did one and it was an OK job. Awkward to get the thing out as you need to remove stuff around it (quite a lot of stuff) but mine took a few hours and I saved about 5 hours of garage labour rates. That does come to the cost of a pint or two and there are worse jobs to take on. Good luck.
Post #449585 31st Aug 2017 7:52am
SFM
Thanks so much mate, will have a look later.
Car is being collected Monday, hopefully should have back Wednesday.
It's just when you disconnect the battery on these, you're screwed to do anything.
Can't turn the ignition key, can't get into glove box etc.
And when connected, you sit there watching it smoke away for 3 minutes, until you can disconnect again.
Don't you just love them?
Post #449589 31st Aug 2017 8:18am
SFM
Going to try to disconnect the alternator today,
Which is the best way to get to the connection, is it even possible without removing the alternator first?
Post #449738 2nd Sep 2017 7:27am
SFM
Can anyone advise on what to do?
Car is being collected Monday morning, at the moment it's in my garage with the battery disconnected.the problem I have is that I need to reverse the car out, and get it to the top of my long driveway for collection.
In order to do this, even if I don't start the engine, I still need to turn on the ignition to undo the steering lock, which needs power to unlock, as soon as I connect the battery, it has a dead short with the alternator, and starts smoking, just really concerned that I will cause more damage.
I have had a look, and can see no possible way of getting to the connections at the rear of the alternator, especially with the position of the car.
Is there not a fuse or similar that I could pull out to disconnect the feed to the alternator?
Or do I just take a chance, and drive the bloody thing up to collection point, wait 2 minutes, and disconnect battery?
What is the worst that could happen, and What would you guys do?
Post #449752 2nd Sep 2017 9:14am
mzplcg
No question, I would disconnect the alternator. Yes it's awkward to get to but it is completely necessary if you want to avoid potential wiring damage.
Post #449754 2nd Sep 2017 10:13am
