Home > Technical (L322) > Adaptive Dynamics - recalibration
GraemeS
Having spotted on my Iidtool, after updating to the latest beta s/w, an option to set adaptive dynamics calibration mode and being very aware that my shocks have not been functioning well for some time, to the extent of being on the verge of ordering new ones, I was keen to see the result of setting calibration mode. The first drive was over my very rough, deeply pot-holed farm driveway then a few kms along a gravel road then back home. The drive back over the bumps and pot-holes was now very controlled (I have the suspension raised 30mm for this section) and not bashing the bump-stops.
The next drive was out to the sealed road and 50 kms to town where the ride was harsher than it should be. On the way home I again set calibration mode then after only a short distance the ride had returned to how it should be. Obviously the road for the first calibration was unusually rough so the shocks were set unusually firm whereas for the 2nd calibration the road was more normal.
The shocks on my previous vehicles have become soft after about 60K kms and totally useless by 80K kms. I had hoped that CVDs would last longer but after 45K kms of my driving plus 20K of the original owner's city driving the shocks had deteriorated to about the same state as those on earlier vehicles had at 60K kms. The shocks are working as new again although I know that they are far from new.
Post #449414 29th Aug 2017 8:56am
interesting...so by setting this would normal road use ride be improved .. ... - .- -.
Post #449415 29th Aug 2017 8:59am
GraemeS
My shocks had deteriorated presumably due to worn piston seals and/or valves from rather severe use, causing small bumps on bitumen roads to be felt as thumps and allowing the vehicle, especially the front, to bounce considerably over big pot-holes, so I knew that damping was no longer anywhere near adequate.
In calibration mode the suspension travel over bumps is monitored against bypass valve operation, possibly for a period of time but perhaps distance or until shock performance becomes acceptable so that new valve opening calibrations can be determined. I'll initiate another recalibration when I detect that the ride has deteriorated sufficiently.
Post #449435 29th Aug 2017 12:57pm
GraemeS
Another re-calibration was done 2 days ago at 93K kms as the ride had deteriorated again, not adequately damping over ruts and bumps and the car jostled about on major rural roads. The ride is good again - for the moment at least. This time I drove at 80 kph on a surface causing a poor ride for the 10 seconds calibration period.
Post #504396 8th Feb 2019 4:45am
