Home > Technical (L322) > Can I lock / unlock with the battery out?
GGDR
Hi guys,
Planning a job that needs the battery disconnected. I'll need to lock it and unlock though during the job (tea breaks mainly!).
Can the blade key do this via the door handle (the bit under the cover?).
The manual covers unlocking, not locking.
Thanks! Cheers, Greg
Post #449173 26th Aug 2017 4:40pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Yep Thumbs Up
Post #449176 26th Aug 2017 4:56pm
not sure but i think it will unlock and lock only that one door. ... - .- -.
Post #449177 26th Aug 2017 4:56pm
CS
I found that I could not get the key to work, though the LR Assistance technician did manage eventually. It's probably just lack of skill on my part, but if you have not used it before it might be worth doing a trial run before removing the battery Only Range Rovers since 1988
Post #449180 26th Aug 2017 5:16pm
JCW
^^ good point! once confirmed it locks / unlocks, when disconnecting / removing the battery when unlocked you then just need to manually lock each door (pressing the black button down) other than the drivers door, which you can then lock / unlock with the key.
Post #449182 26th Aug 2017 5:19pm
GGDR
Brilliant - thanks guys.
My key-able lock is on the front passenger side - seems odd.
But I'll give it test or three before I whip the battery out.
Thanks again all.
. Cheers, Greg
Post #449189 26th Aug 2017 6:13pm
GGDR
This is such a great forum!
. Cheers, Greg
Post #449191 26th Aug 2017 6:15pm
