![]() | Home > Technical (L322) > Can I lock / unlock with the battery out? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
Yep |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
not sure but i think it will unlock and lock only that one door. ... - .- -.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
I found that I could not get the key to work, though the LR Assistance technician did manage eventually. It's probably just lack of skill on my part, but if you have not used it before it might be worth doing a trial run before removing the battery Only Range Rovers since 1988 |
^^ good point! once confirmed it locks / unlocks, when disconnecting / removing the battery when unlocked you then just need to manually lock each door (pressing the black button down) other than the drivers door, which you can then lock / unlock with the key. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Brilliant - thanks guys.
This is such a great forum!
