Home > Technical (L322) > air suspension locked
bogie
I have the same issue, seems to be cold related though ....when its -10 outside, first thing in the morning get the error, and sometimes the transmission lock err
once warm a restart and it goes ...sometimes just switch on/off ignition, move gear to Neutral and back does it
so I guess a sensor or battery
but it had a new battery (supposedly) on the service before I bought it ...looks new, documentation/invoice shows it was new, so who knows.... cheers
bogie
Post #43338 23rd Dec 2010 3:29pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
It appears most of you have cured the EAS faults, but one thing to remember if your car has the factory tow kit fitted is that there is also a sensor in the towing electrics that detects when there is a trailer plug plugged in and that also locks the suspension when towing - it the spring loaded cap on the socket in the towing subframe has not fully closed you could be getting salty road water in there causing the system to think there is a trailer plugged in - a quick spray with something like electrosolve water disperser and checking the cover has seated properly might also cure the problem. A long shot but in the current UK weather and lots of road salt being liberally sprinkled around could be contributing factor for those who tow. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #43396 24th Dec 2010 2:09am
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
dan_uk_1984 wrote:
reynolds wrote:
does any one no where the obd port is located on 2004 diesel autobiography
Same place it is on every L322. In the coin tray by your right hand knee when sat in the drivers seat...
I have one of these: http://www.rswsolutions.com/index.php?opti...;Itemid=77 and it's a lot of bang for your buck!
Hi all, first of all I have to say what a great forum, so much helpful info on just about everything,
I’ve just had a look at the eas buddy reset tool, looks great but does anyone know if you can get one of these for a 2006 ffrr???
Post #44914 6th Jan 2011 7:00pm
I would check that the Battery Terminals are clean and that the cables are properly secured. Dan did a post on this.
Post #44918 6th Jan 2011 7:12pm
