Home > In Car Electronics (L322) > HK Denso audio problem
Monsavon
France
hello everyone
first of all, im french so sorry for bad spelling.
i just got myself a L322 HSE TD6, from 2005, it seem to work fine for the most part, got 200 000 KM, all oil change and all.
but here come the problem, it is equiped with the Harman infotainement system, the previous owner said me he had a sound prob with it, and his mecanist just disconneted it.
he did it by unpluging everything from the head unit. so i did reconnect.
problem, it got the LR logo frozen, since before that i already look at forum, i know what the prob should be. so i enter Hiden menu, and confirm MOST ring failur.
after some test, it was the nokia BT modul, i bypass it and everything seen to come back again.
but some new problem apeared, i have the nav working, the connection to OBD ok (every info and 4x4 screen), i have radio working, but no CD, no TV, and some key or turn buton dont work on the head unit. i cant change volume with the hea unit, but i can with the streering wheel command, i cant change the presset for Bass,Mid,Hight nor the balance.
i tried to enter hiden menu again to test the key entry with the diag, but im now unable to enter it.
anyone have a way or may know of what part of the system is broken ?
i already look at the forum to the 40th page without finding the same kind of problem
thank you, Monsavon
Post #440433 2nd Jun 2017 1:34pm
Welcome,
before Stan comes on here and suggests it, try a battery reset of the system, the information is in the WIKI at the top, this may or may not help but is easy, free and does work in some cases.
It sounds like you have found the solution to the Nokia module, there is a method with a BIC biro to bypass the unit, which is detailed on here. There is nothing that can't be fixed with a hammer😜😜
Post #440451 2nd Jun 2017 4:52pm
try a battery reset........ Mr. Green ... - .- -.
Post #440452 2nd Jun 2017 4:58pm
Monsavon
France
sorry i forget to update the post, i just copy past from an other forum.
i already did a hard reset, tested all fuse, i also tryed the firmware update, but i may had a bad copy of the DVD as it made nothing but make the screen blink from black to LR logo.
i did manage to get the hiden menu back, but still nothing for the other problem
Post #440464 2nd Jun 2017 5:22pm
Weegie
To be pedantic the procedure for a hard reset isn't in WIKI (unless I am missing something). Battery disconnect and reconnect are but not the extra bit for the reset> John
GAP iiD BT
Post #448676 22nd Aug 2017 11:58am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
well if its anything like the HK system in my Mercedes , one of the units will have failed , they are very unreliable , mine needs a new amplifier
Post #448765 22nd Aug 2017 9:16pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi I have a similar problem I have just posted details about the issue I have really strange that after I did a rest by taking the main fuse out for the the infotainment system. I then waited for 10 minutes and also disconnected battery upon reconnecting the battery I noticed my date was back to Dec 2003 how can this be if my car was manufactured back end of 2005 and when I replaced a battery on the car a few months ago the date went back to Sept 2005 which would make sense as a default setting as the car was made 2005 an ideas is this suggesting a software update or something which could cure the problem with the infotainment system I have.
Cheers
Jay
Post #448946 24th Aug 2017 1:36pm
jaysta10k
Hi did you manage to sort out this problem as I have the exact same issue and cannot get to the bottom of it.
Cheers
Jay Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #450144 7th Sep 2017 6:20am
Monsavon
France
i managed the probleme, only by changing the main unit.
Post #450807 13th Sep 2017 12:02pm
jaysta10k
Hi you say that you changed the main unit do you mean the touchscreen or the unit behind the touchscreen.
Cheers
Previous Cars
BMW M3 Carbon Black
Post #450895 14th Sep 2017 9:15am
Monsavon
France
the touchscreen.
Post #450914 14th Sep 2017 1:17pm
jaysta10k
Right ok thanks for this I have checked every module on my vehicle and bypassed them so it must be my touchscreen also that is causing the same problem that you had. I cannot turn the volume up or down on headunit I cannot select TV , CD, DVD, AUX but I can select REAR SEAT SCREENS and watch TV ,DVD on them it's just limited functions on the main unit. Also I cannot access voice recognition but I can access 4x4 info and the trip computer and the sat nav works also.
Cheers
Previous Cars
BMW M3 Carbon Black
Post #450916 14th Sep 2017 1:43pm
