![]() | Home > In Car Electronics (L322) > HK Denso audio problem |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8674 ![]() ![]() ![]() |
Welcome,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
try a battery reset........ |
Monsavon Member Since: 02 Jun 2017 Location: bordeaux Posts: 4 ![]() ![]() |
sorry i forget to update the post, i just copy past from an other forum.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
To be pedantic the procedure for a hard reset isn't in WIKI (unless I am missing something). Battery disconnect and reconnect are but not the extra bit for the reset> John
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
well if its anything like the HK system in my Mercedes , one of the units will have failed , they are very unreliable , mine needs a new amplifier |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi I have a similar problem I have just posted details about the issue I have really strange that after I did a rest by taking the main fuse out for the the infotainment system. I then waited for 10 minutes and also disconnected battery upon reconnecting the battery I noticed my date was back to Dec 2003 how can this be if my car was manufactured back end of 2005 and when I replaced a battery on the car a few months ago the date went back to Sept 2005 which would make sense as a default setting as the car was made 2005 an ideas is this suggesting a software update or something which could cure the problem with the infotainment system I have.
Hi did you manage to sort out this problem as I have the exact same issue and cannot get to the bottom of it.
i managed the probleme, only by changing the main unit. |
Hi you say that you changed the main unit do you mean the touchscreen or the unit behind the touchscreen.
the touchscreen. |
Right ok thanks for this I have checked every module on my vehicle and bypassed them so it must be my touchscreen also that is causing the same problem that you had. I cannot turn the volume up or down on headunit I cannot select TV , CD, DVD, AUX but I can select REAR SEAT SCREENS and watch TV ,DVD on them it's just limited functions on the main unit. Also I cannot access voice recognition but I can access 4x4 info and the trip computer and the sat nav works also.
