Home > Technical (L322) > TDV8 turbo replacement engine in CAR. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Go for the 4.4 TDV8 and you will have much less to worry about. More expensive? Yes. But probably cheaper in the long run. 2006 4.2 SC
20th Aug 2017 8:26am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
I have to be honest, I saved longer to get the 4.4 as I didn't need the worry - however valid,
20th Aug 2017 2:39pm |
SteveRRL322 Member Since: 23 Oct 2016 Location: Kent Posts: 128 |
I'm just wondering how many people who say 3.6 tdv8 turbos go reguarly actually have owned one and have had the turbos fail???? Or is it I heard it from a bloke who knew a bloke who might have had a problem?
20th Aug 2017 3:17pm |
I take your point, but I'd rather spend £25k on a 4.4 than £25k on a £17k 3.6 that went pop and I had to fix or have a very expensive paperweight. Would be my luck and all that....
20th Aug 2017 3:52pm |
MartinM Member Since: 19 Dec 2015 Location: Oslo Posts: 16 |
OK
20th Aug 2017 4:02pm |
As with everything mj it is down to how you use and look after it. Rag it when cold and don't service or service it and drive it every day like miss daisy then you may have problems. Play football everyday and lift heavy weights all the time and you will wreck your knees but you never hear people say "well I'm am not going to get a pair of knees I have heard that they always
20th Aug 2017 4:08pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1365 |
I think it is on the full fat RR, but not on the RR Sport. V8 or else ... |
20th Aug 2017 4:15pm |
The left one is not that hard but the right one is a pig with the engine in and it is best to do them in pairs. |
20th Aug 2017 4:20pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1760 |
Engine stays in the car, sort of
20th Aug 2017 6:41pm |
Sport is body off, around 2.5 hours work to access the turbos |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Wow.......since you're in Dundee Mikey, do you eat cow pies too? Mike |
20th Aug 2017 7:55pm |
Steak pie? |
20th Aug 2017 9:09pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1381 |
Surely that should be peh? Only Range Rovers since 1988 |
21st Aug 2017 11:02am |
Was thinking more like Desperate Dan if you've replaced turbo's at the side of the road
21st Aug 2017 5:46pm |
