Home > Technical (L322) > TDV8 turbo replacement engine in CAR.
MartinM
Norway
I am dreaming about buying a TDV8 however the turbo issues scares me a bit. Can the turbos be replaced with the engine in the car? Can it be done by a skilled hobby mechanic??
Br Martin
Post #448432 20th Aug 2017 7:21am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Go for the 4.4 TDV8 and you will have much less to worry about. More expensive? Yes. But probably cheaper in the long run. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #448436 20th Aug 2017 8:26am
mjdronfield
I have to be honest, I saved longer to get the 4.4 as I didn't need the worry - however valid,
I know it's not answered your question...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #448469 20th Aug 2017 2:39pm
SteveRRL322
I'm just wondering how many people who say 3.6 tdv8 turbos go reguarly actually have owned one and have had the turbos fail???? Or is it I heard it from a bloke who knew a bloke who might have had a problem?
By the way it is mainly tdv8 Range Rover sports that have turbo problems as the engine bay is smaller and there is less air flow.
4.4 turbos actually have problems as the second turbos don't get used as they don't cut in till 2500 rpm and most people don't take them above them, well so my brothers friends, cousins aunt told me maybe 😂
P.s
Don't read forums whilst drinking gin, it makes u evil 👹
Post #448473 20th Aug 2017 3:17pm
mjdronfield
I take your point, but I'd rather spend £25k on a 4.4 than £25k on a £17k 3.6 that went pop and I had to fix or have a very expensive paperweight. Would be my luck and all that....
And if you fancy a facelift one with digital dash, it's even more of a no brainer.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #448482 20th Aug 2017 3:52pm
MartinM
Norway
OK
Problem is the availabilty and pricing of the 4.4. Most V8 diesels are 3.6 in Norway.
......back to my question. Is IT possible to change the turbos with the engine in the car?
Martin
Post #448488 20th Aug 2017 4:02pm
SteveRRL322
As with everything mj it is down to how you use and look after it. Rag it when cold and don't service or service it and drive it every day like miss daisy then you may have problems. Play football everyday and lift heavy weights all the time and you will wreck your knees but you never hear people say "well I'm am not going to get a pair of knees I have heard that they always
Give you problems" 😂
The knees part is the gin talking by the way Thumbs Up Rolling with laughter
Post #448489 20th Aug 2017 4:08pm
fisha
I think it is on the full fat RR, but not on the RR Sport. V8 or else ...
Post #448490 20th Aug 2017 4:15pm
SteveRRL322
The left one is not that hard but the right one is a pig with the engine in and it is best to do them in pairs.
Post #448494 20th Aug 2017 4:20pm
Mikey
Engine stays in the car, sort of Whistle
Right hand turbo can be done in a few hours
LH turbo needs:
Exhaust manifold off
Engine mount bracket off
Diff off
Engine mount off
Subframe off
Steering rack off
That said, I have done them at the side of the road, so nothing hugely difficult. Just fiddly and time consuming Thumbs Up
Post #448508 20th Aug 2017 6:41pm
Mikey
Sport is body off, around 2.5 hours work to access the turbos Thumbs Up
Post #448509 20th Aug 2017 6:41pm
mpirie
Wow.......since you're in Dundee Mikey, do you eat cow pies too? Rolling with laughter
Mike
Post #448515 20th Aug 2017 7:55pm
Mikey
Steak pie? Whistle Thumbs Up
Post #448523 20th Aug 2017 9:09pm
CS
Surely that should be peh? Laughing Only Range Rovers since 1988
Post #448556 21st Aug 2017 11:02am
mpirie
Was thinking more like Desperate Dan if you've replaced turbo's at the side of the road Bow down
Hence the cow pies! Thumbs Up
(Maybe i'm showing my age here!) Big Cry
Post #448584 21st Aug 2017 5:46pm
