Home > Technical (L322) > Key programming strange results from 11D |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Morning all so I have 3 keys for my ff and I can program any 2 out of the three to start the car I can program all 3 to open the door and I can program only one at any one time to operate remotely - all three can be the one that operates remotely but can't get more than 1 at a time same with car starting - totally confused Help |
21st Aug 2017 9:58am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
When you are pairing the keys to the car you should only put the first key in the ignition. After that continue with the other keys but do not put them in the ignition. If you do you are starting the process all over again.
21st Aug 2017 10:28am |
Sorry for the confusion I am using the Gap 11d Tool so put first key in then you literally just put each key in to ignition one after the other - I have tried doing the key position technique and get same results wondering if there is an eco for keys and it has failed/failing |
21st Aug 2017 10:33am |
ECU as opposed to eco |
21st Aug 2017 10:34am |
