Home > Technical (L322) > Transfer box motor? |
Ed Sanders Member Since: 17 May 2017 Location: Midlands Posts: 3 |
Thanks, I'd missed that one somehow cheers |
18th May 2017 2:37pm |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 182 |
I had sometimes the "Transfer Box Neutral" Message on desk.
15th Jun 2017 5:39pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
The transfer boxes used in the 02-05MY 4.4 V8 and the 02-06MY 3.0 TD6 are the same, except that the diesel has an additional vibration damper bolted to it
15th Jun 2017 11:41pm |
thank you for the info! |
17th Jun 2017 8:25am |
Motor arrived today, it will be in car on Friday when i'm at the workshop! Total: 440 Euro incl. Shipping and Customs.
14th Aug 2017 9:32am |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 |
I tried to understand if it is possible drive the car with TCASE plug disconnected, form the t case motor and without problems like error messages, (Obviously not using low range ) in this case will appear Failsafe programm message or other or not?
19th Aug 2017 12:14pm |
Just speculating here, because I don’t know the answer, but each time the ignition is switched on the transfer box ECU tells the shift motor to drive the shift fork to its mechanical stop for the range it was in when it was last turned off. This is how it calibrates itself. The only feedback the ECU receives regarding the position of the shift fork is from the potentiometer so I’d be surprised if removing the plug didn’t trigger the failsafe message as the ECU would be seeing no response during this calibration process.
19th Aug 2017 7:00pm |
i removed the fuse till i hade the new motor, worked fine for me, your motor has to be in high range first!
20th Aug 2017 9:15am |
