Home > Technical (L322) > 2004 Sat Nav Question |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I've just received one which I purchased for £100, but it was listed for 'spares or repair' since it has a disk read error. This seems to be quite common, and the fix is either £150 purchased through ebay, or can be done as a diy by the very brave.
22nd Dec 2010 11:19am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35433 |
re burning david, get a dual layer disc.... ... - .- -.
22nd Dec 2010 11:35am |
bit of confusion here..
22nd Dec 2010 2:57pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi scarey, yes your right but, i thought we were talking mk4 unit that was in the pr touch screen... V8 facelift Range Rover Autobiography 22" wheels.
22nd Dec 2010 7:57pm |
you know that i dont read the posts properly dave.. ... - .- -.
22nd Dec 2010 8:00pm |
We are, does that mean I've downloaded the wrong files? I got them from myrangerover.co.uk time to do a little more googling methinks! Range Rover-less at the moment - Pining! |
22nd Dec 2010 8:01pm |
ok, the downloads links that have be posted will allow you to download a v3.2 update disc and map are for the mk4 dvd unit that you find on the x5 and most people ugrade with on the pre touch screen. not the later denso unit that can be identified by the lock switch on the right hand side as you look at it and as scarey said you will need a duel layer burner to do a map/update disc,
22nd Dec 2010 8:09pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1738 |
completely confused now.
5th Jan 2011 8:52pm |
hi, you burn one file to each disc, end up with 2 disc, do not unzip any thing.the map should be done as slow as poss. the v3.2 should be a small file around 550mb and the map will go on a standard dvd, unless you have downloaded the map for 2005 and later, that needs a duel layer and will not work in the mk4 units V8 facelift Range Rover Autobiography 22" wheels.
5th Jan 2011 10:10pm |
making an educated guess here..sounds like the small file is the firmware update which you put in first then take out and put the large disc in which holds the mapping...it also sounds like the language has defaulted to french, go into the menu and change that.... ... - .- -.
6th Jan 2011 8:32am |
Thanks Daveo,
6th Jan 2011 8:39am |
Hi Folks - I know I've seen it here somewhere but search did not find it for me. Is there a list of part numbers for what model DVD Nav unit will work in a RR (a MKIV BMW unit)
7th Jan 2011 10:27am |
ashley, have you a working cd and dvd and have you tried both... |
7th Jan 2011 10:36am |
HI Scarey - Just tried a working dvd from a donor car. same message on screen to insert correct CD/DVD. Not tried a CD as this is the DVD system isn't it do a CD wont work anyway.? Ash
7th Jan 2011 10:39am |
