Home > Technical (L322) > Varta battery
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Varta battery
Can anyone tell me if the positive terminal on the Varta battery is of a substantial girth?
Reason for the oddball request is that I can't tightenten the positive clamp on mine, not matter what I do it's always loose, which obviously causes problems.
I've just looked at the battery, and the positive terminal is slightly smaller in diameter than the negative. Shocked
Post #448017 16th Aug 2017 9:31am
Wogger
Forgot to add, it's not a Varta battery on my motor
Post #448018 16th Aug 2017 9:32am
Clivefog
Asian motors often have a smaller + terminal, is this a new battery if so it has the wrong post size.
Post #448029 16th Aug 2017 11:58am
Wogger
Yep, less than a year old Shocked
Post #448032 16th Aug 2017 12:15pm
I've got 4 newish Varta batteries and all of them have the same posts. The positive posts are all larger diameter than the negative posts by about 3mm. If your clamp isn't tightening you can either widen the clamp so that it sits further down the post before tightening it, pack the clamp out by inserting a piece of lead or flattened copper pipe and tightening or buy a new clamp. Thumbs Up
Post #448033 16th Aug 2017 12:52pm
Clivefog
Buy a new clamp for a Japanese import.
Post #448044 16th Aug 2017 3:38pm
Wogger
Getting me hands in a Varta battery to see if it has a bigger post, if not, it's a new clamp.
Rolling Eyes
Post #448048 16th Aug 2017 4:09pm
