Home > Technical (L322) > Varta battery |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Forgot to add, it's not a Varta battery on my motor |
16th Aug 2017 9:32am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Asian motors often have a smaller + terminal, is this a new battery if so it has the wrong post size. |
16th Aug 2017 11:58am |
Yep, less than a year old |
16th Aug 2017 12:15pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3970 |
I've got 4 newish Varta batteries and all of them have the same posts. The positive posts are all larger diameter than the negative posts by about 3mm. If your clamp isn't tightening you can either widen the clamp so that it sits further down the post before tightening it, pack the clamp out by inserting a piece of lead or flattened copper pipe and tightening or buy a new clamp. |
16th Aug 2017 12:52pm |
Buy a new clamp for a Japanese import. |
16th Aug 2017 3:38pm |
Getting me hands in a Varta battery to see if it has a bigger post, if not, it's a new clamp.
16th Aug 2017 4:09pm |
