Home > Maintenance & Mods (L405) > L405 Tow Hitch
Page 2 of 5 <12345>
No adjustment with the electric one.
There's some adjustment on the 'fixed' one, but not sure how much.
Post #447041 8th Aug 2017 9:21am
Dte1
United Kingdom 2009 Range Rover Vogue TDV8 Causeway Grey
Thanks for a quick reply.
Post #447050 8th Aug 2017 11:14am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I looked at the electrically retractable when I ordered mine, but understand that it's not just a lower noseweight off road, but a lower weight capacity too. That's definitely not what I want!
I currently use a 3 point mounting, adjustable height, but fixed in position tow bar on the D4 that allows me to fit a combined tow ball and jaw. Not sure what to fit to the FF, especially as I'd prefer to avoid anything that's removable or retractable.
I fear I might be out of luck...
Post #447062 8th Aug 2017 1:15pm
As far as the manual goes - weight capacity is the same
It appears that it's still a fairly healthy nose weight, albeit reduced slightly.......
'unrestricted' nose weight is still 150kg
'restricted' nose weight is only 200Kg vs 250 for the non-retractable one.
However, if I read it correctly, the 'restricted' only applies if there's a speed limiter on the vehicle - but maybe it's OK as long as you stick below 60 anyway.....
Post #447065 8th Aug 2017 2:01pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
I have the LR removable one. Square section male connector on the hook that slides into a square section female connector on the car - this has a rubber push in cover when the hook is not in place. Large 'L' shaped pin with R spring clip to retain it. Came in a little zip bag. You can adjust height as there are 4 bolts holding the towhook to the plate that is on the end of the male connector. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #447962 15th Aug 2017 7:25pm
How high is the top of the tow ball from the floor ?
And what would it be on the other setting / how far apart are the holes ?
Post #447994 15th Aug 2017 10:06pm
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Any chance of someone with a LR removable tow bar for the 405 please posting some photos of the rear of the car with the tow bar removed and the rubber cover in place? I've seen the stock LR brochure pictures but would find it helpful to see a real world example.
Cheers. 2016 SDV8 AB
Post #448019 16th Aug 2017 9:34am
Red Merle
Alistair wrote:
Alistair,
Thanks for the copy of the manual from the 8th of August. The bit that I didn't see the first time that I read your scanned image was the bit that said:
"Note: The powered tow bar option is limited to 1,000 kg for off-road use".
I wonder what the mean by "off-road use"? At what point does a grassy field become rough enough to be considered "off road", especially with, say, a large and fully loaded horse box? This is the limitation that stopped me from buying one as I'm more likely to use it more frequently for off-road recovery, or retrieval of a trailer from a field than I am to use it on the road.
PS: A friend was killed in a RTA, about 2 years ago, when his car was hit by a trailer that had became detached from a LR. This is why it's a bit dear to my heart and why I won't compromise on the strength of a tow bar.
Post #448022 16th Aug 2017 10:16am
RR2008HSE
On road you're getting a very straight pull. Off-road, the pull will be at all angles and often switching angles quickly. If your towing area is flat/smooth, it shouldn't be a problem. Also, the slower you go, the less stress, so low range and set it something like rock crawl if you get to anything uneven.
Post #448215 18th Aug 2017 1:09am
Red Merle
It shouldn't be a problem for those going to level and smooth campsites, with no traction problems but, for anyone using it as a Land Rover is intended, to have to say "sorry, I can't recover your Nissan Navara from that boggy field you've got it stuck in", or "that trailers going to have to stay where is is, because the field you've got it stuck in is a bit bumpy because my tow bar is too weedy and it might snap off" would be a bit rubbish! Rolling Eyes
I'd be a lot happier if it mentioned the use restrictions in the sales particulars, rather than the small print in the manual and if they provided some properly robust alternatives Thumbs Up
Post #448218 18th Aug 2017 4:49am
CS
I'm not sure about using 'rock crawl' for towing, as this automatically puts the car on the high suspension setting, which having a trailer connected would block from happening. 'Grass gravel snow' might be better.
Red Merle, does your new car have 'Advanced Tow Assist'? I have seen it demonstrated on a D5, apparently it adjusts the height of the car to suit the trailer, so e.g. your two axles are level, I think it can also test weight. If I were buying a new 405 I would specify that plus the non-electric towbar, that should be the best set-up though that towbar does stick out rather and might be better removed when not needed, to aid departure angle and parking space issues. My guess is that with decent tyres such as Goodyear Duratrac 255/55R20 you should still be able to do normal off road towing as you do in your D4, the practical limit is more likely to be on your own traction rather than the towbar mount, assuming you are not in Australian outback - type conditions. Only Range Rovers since 1988
Post #448247 18th Aug 2017 10:57am
Triarii
I would upload a picture of the tow hook with rubber cover but can't get the upload to work! Embarassed 17 MY Corris Grey 4.4 VAB
Post #448308 18th Aug 2017 4:37pm
Red Merle
Alistair wrote:
I had removable on my L322 & have deployable on my L405
Removable
pro's - cost - I was quoted £1k for an L405 by a MD - so only a pro vs deployable Whistle
Height adjustable (a bit)
cons - visible 50cmx50cm square receiver when not in use - see pic below - even with the panel fitted, you see the square reciever - it's not obtrusive, but it's there....
Heavy component to be fitted when you need it with no obvious place to store - you'd probably need to tie it to a D ring in the boot as you wouldn't want it moving about.
Not sure if the L405 one is held in place with a pin or needs a bolt tightening - if the former, probably a bit rattly, if the later a PITA
Deployable
pros - invisible when not in use - deploys at the touch of a button Cool
cons - cost - I was quoted £3k by a MD Shocked
Reduced nose weight capacity when towing off road (if that's a concern)
Fixed height
I’m looking for one of the adjustable height ones, but can’t find one anywhere. I can find the removable bit, but not the part that is mounted to the car.
Does anyone know where to source one?
Post #453560 10th Oct 2017 6:04am
Looks like main dealer only - I've not seen one anywhere else - so maybe try Matfords or Dan ?
It doesn't't seem to be a Westfalla like the L322 was - that one now looks different and I've not seen one on a car - here's a link to PF Jones who used to be the best source of L322 tow bars.
Post #453562 10th Oct 2017 6:58am
Red Merle
Thanks Alastair, I shall follow those up.
Post #453570 10th Oct 2017 9:25am
Page 2 of 5 <12345>
