Home > Maintenance & Mods (L405) > L405 Tow Hitch
Page 4 of 6 <123456>
Looks very different to me - if you scroll up to the pics - looks more like a Disco unit
The LR removable one is the same concept of a 2" receiver, but the Westfalla one looks different.
Post #482182 29th Jun 2018 11:44am
I feared that Alistair... Couldn’t possibly be that easy!!! Neutral
Post #482184 29th Jun 2018 11:59am
CUE99T
I'll get the part numbers off mine shortly and post up.
Tbh the frame is exactly the same as the electrical one. I'm not quite sure why they don't sell it at the MD. all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #482186 29th Jun 2018 12:11pm
CUE99T
and it has same detachable unit as andy's
2006 Vogue
2004 Vogue
2001 Vogue
Post #482190 29th Jun 2018 12:26pm
CUE99T
2006 Vogue
2004 Vogue
2001 Vogue
Post #482291 30th Jun 2018 9:25pm
Hi Chaps,
Gearing up for a 405 soon ish I think.
I’ve hit the same “there’s no detachable option” from dealers, £450 quote fitted from my local installer.
I’ve had a read through, what’s the panel part number needed, the one with the hole for the deplorable with the extra material cut out? There is nothing that can't be fixed with a hammer😜😜
Post #544221 17th Feb 2020 5:10pm
L405 tow cover - search eBay - there’s usually a few sub £30 and will likely have the part number too Thumbs Up
Post #544238 17th Feb 2020 7:59pm
Cheers Alistair. There is nothing that can't be fixed with a hammer😜😜
Post #544253 17th Feb 2020 9:59pm
p/n CK5M-17K950-CA Thumbs Up ... - .- -.
Post #544255 17th Feb 2020 10:11pm
CUE99T
TBH Mine isnt off and on much and I just rescrew the platsic clips in with the key fob plaque.
If you take it off and on a lot then might be worth it. I'd try it first.
P all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #544260 17th Feb 2020 10:44pm
Cheers Chaps. There is nothing that can't be fixed with a hammer😜😜
Post #544352 18th Feb 2020 8:06pm
YMFB
England 2016 Range Rover Vogue SE SDV8 Causeway Grey
I’ve been shopping around on line and come up with a wide range of prices from a detachable towbar for a 2016 Vogue.
RR deployable £3,300 not sure if that was incl or excl VAT, but it’s not happening.
RR detachable £1,500
Mobile fitted at home £650 to £1,120.
The £650 is Towbars and towing
It’s only required for a Thule two bike carrier to transport lightweight road bikes.
What possible advantage is there of paying nearly double for the RR detachable towbar ?
Post #561639 15th Jul 2020 10:27pm
Mr Tee
Land Rover written on the box basically
Post #561643 15th Jul 2020 11:07pm
Land Rover don’t specifically do a detachable OE one. Deployable or drop plate only (which is kind of detachable)
The westfalia one is the properly detachable one. The unit is cheap enough and PF jones is a good place to start. I got a local place to fit mine. Quite reasonable really but some have done it themselves on the drive. westfalia made the tow bars for the 405 so are as close to OE as you can get for a detachable swan neck. There is nothing that can't be fixed with a hammer😜😜
Post #561654 16th Jul 2020 6:48am
Phil.
Had PF Jones fit a detachable Westfalia tow bar on my 405 on my drive a couple of weeks ago. £770 inc. VAT. It’s great, easy to pop on and off. So is the cover underneath. No need to cut the cover unless you want to leave the tow bar on for an extended time. Works a treat with my Thule bike rack. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #561679 16th Jul 2020 9:32am
