Home > Maintenance & Mods (L322) > Front suspension air bag replacement
Andyyav
United Kingdom 2018 Range Rover Vogue SE SDV8 Carpathian Grey
So lots of warning messages and some basic checks later I've a hole in the drivers side front suspension air bag, I've had a search but can't really see an obvious answer to my questions-
Can I drive it for a few days while wait fir parts etc?
Passengers side was replaced just before I bought it with a Dunlop, I'm thinking Delphi as they get better reviews on here, will having one of each have any affects?
Once I've replaced it (which correct me if I'm wrong looks fairly straight forward) do I need to reset anything with diagnostic tools etc?
I don't want to replace it ignoring the above and find I'm in a worse place!
Post #447664 12th Aug 2017 10:29pm
1. Drive it ?
You can, but run the risk of further damage - overheating compressor etc requiring replacement as well. Or the hole getting worse and leaving you stranded on the bump stops. I wouldn't....
2. One of each?
Shouldn't make much difference, and yes Delphi are seen as being a better option. Most agree that front struts should be fitted in pairs, but depends on how long ago your Dunlop one was fitted, if £££ is an issue.
3. Post fit?
No diagnostics specifically needed, depends if you have a hard fault on the EAS (doesn't reset after ignition cycle or battery reset. If so then yeas a diagnostic tool will be needed to reset the air suspension. You may need to calibrate, also depending on what heights you get at each wheel once up and running.
There is a howto on the wiki Thumbs Up .
Post #447666 13th Aug 2017 12:40am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I have driven mine with a holed airbag for 2 weeks. Driver side front first went so drove whist waiting for replacement then after fitting the new strut the passenger side split immediately after the suspension pressurised so I highly recommend doing both unless you are sure the other is newish. The second weeks driving awaiting the second strut to arrive.
The car drove surprisingly well, with the suspension fault message on however I took things very steady especially braking and turning. Braking on a loose surface cause the offending corner to skid even under the lightest brake pressure but the car still stopped well. I had no real option other than to continue to drive but would not have done so given access to another car.
The Struts were very easy to fit, use axle stands both sides or prepare for major dramas and injury. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #447688 13th Aug 2017 9:31am
Andyyav
joe90 wayneg Thanks for the info,
The dunlop is under a year old and looks new, guess in the spirit of something else may break soon ill keep the cash for that!!
Ive not got any 'hard' error messages just intermittent - vehicle raising slowly and suspension will lift when system has cooled so hopefully no more pain there (i replaced the rear axle on my P38 and ended up needing to set the suspension up via laptop hence the concern)
The wikis great ill get out this afternoon and strip it out, should have time to collect and fit one from JSF in norwich tomorrow
Thanks again Andy
Post #447708 13th Aug 2017 1:03pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Getting ready to replace mine. RAVE always makes it sound like things are easy and straight forward. My lineage must go back to Capt. Murphy. What major drama and injury should I prepare for? Is it best to lift both front sides? I made the stupid error just last month with doing my BMW front struts and was only lifting one side at a time. Is the track rod ball smaller than the control arm ball? My ball joint separator is only 3/4 inch wide and didn't fit. Needed 20mm. How tight do you make the air tube connection. 3.2 NM sure is much. Do they even make a torque device to measure that small?
Never mind. NM not inch lbs. Duh. Roughly 30 inch lbs.
Post #458753 28th Nov 2017 12:45am
You don't need to have both sides up in the air, but as you will need to depressurise (unless you do the Storey Wilson valve block trick) you may as well drop the front onto its bump stops then get the whole front of the car in the air. You need weight on the wheels to help push all the air out of the air bag. I don't remember removing the track rod ends when I did mine.
Biggest issue will be how tight the strut bolts are. You may need a long long extension on your breaker bar.
Also, if you can, leave the original fittings on the air pipe. .
Post #458790 28th Nov 2017 10:44am
Weegie
^^+1
No need to remove track rod ends just the drop links. And completely concur with point about undoing the bolts.
For the additional cost it would be worth considering new bolts as, if they are as tight as mine were, you may end up with them damaged when removing. John
GAP iiD BT-Sold
Post #458794 28th Nov 2017 11:03am
doclees
Thanks guys. I have an impact gun and pipe extension for my ratchet. I'd be more worried getting it back on to that torque. Without a lift there always seems to be something in the way to be able to get your weight into it. I assume the iidtool can depressurize an individual strut enough to be able to drop it to disconnect the air line. Wouldn't that get any residual air out?.
Post #458831 28th Nov 2017 3:35pm
My experience has been that if you depressurise a corner while the wheel is in the air, the air bag remains inflated, though not under pressure. This is probably more of an issue with the rear bags than the front ones though. .
Post #458835 28th Nov 2017 4:19pm
doclees
Well I dug into the air bag swap today. As usual i had help from Capt Murphy but just in a small way. First I took the advice from the iidtool instructions and deflated everything. Lifted just one side. I struggled with the end link nut because you need to access the shaft side from the forward side of the strut to get a solid grip. Once the nut was off it was obvious the sway bar was still stressing the end link so I lifted the other side and popped out the end link.
Next was the large strut to spindle nuts. I feared them as Scrooge feared the ghost of Christmas yet to come but they were not bad. The bolts were a different story. The lower one was not interested in moving. Took a good hour of PB Blaster, impact gun, hammering and wiggling the spindle to get the bolt to start to rotate in the spindle. Once out I found it prudent to remove the rust on the bolt with a wire wheel and coat with anti seize so not to go through that in 75k miles. Now I've run out of daylight and warmer weather until tomorrow. I have placed the new strut in place in the spindle and attached to air hose with new O ring. Just waiting for the morning.
Post #459262 2nd Dec 2017 5:20am
Re: Front suspension air bag replacement
Spray the big bolts with some form of penetrating oil NOW then Tomorrow & the next day until you do the job... You have a much better chance if they ave already seized... Thumbs Up
I would bare the extra cost and change both at the same time with the Delphi option sir... MUCH safer that way Bow down
Maybe change the rear shocks too (not a huge cost) that way you get 4 new shockers together Thumbs Up
Post #459316 2nd Dec 2017 3:31pm
