Home > Technical (L322) > Vibration &a transmission/drivetrain... |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
classic signs of torque on converter.
4th Aug 2017 7:43pm |
SamUK Member Since: 29 Jun 2017 Location: South Posts: 32 |
Damn! Could be a costly fix then!
4th Aug 2017 8:00pm |
40k since replacement miles including towing on a TD6 Gearbox could easy need a new torque converter again.
5th Aug 2017 9:26am |
Ok, I had thought that.. So is that thudding between gears at low speed and rpm also Torque converter related or is that gearbox? I don't want to be changing the torque converter to find out it's the box as well you see.
5th Aug 2017 10:41am |
rodp Member Since: 09 Apr 2017 Location: The Black Country Posts: 318 |
It seems Birch's in Liverpool have a good name ?? |
5th Aug 2017 11:08am |
Hi guys..
9th Aug 2017 9:10pm |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Sounds like your box is on the way out....
9th Aug 2017 9:36pm |
Exactly those symptoms yes...
10th Aug 2017 8:03am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 827 |
I would pm RRPhil he's the only one that can tell you definitively what's wrong with your gearbox and give you an idea of how to remedy it.
10th Aug 2017 8:19am |
My worry would be the friction modifier has cured the symptoms but not the problem....filter and fluid would be the next move id make.
10th Aug 2017 8:35am |
Haha.. I agree, the range rovers are ridiculously comfortable, for a 4x4 there spot on, more comfortable than the new Mercedes Gml 4x4 ( I've been in one) in fact.
10th Aug 2017 9:11am |
Does he do the TD6 box and TC ? How do we get hold of him? |
10th Aug 2017 1:28pm |
As I mentioned, pm him on this forum and I'm sure he'll give you some sage advice. He's helped countless members on here.
10th Aug 2017 1:44pm |
