Home > In Car Electronics (L322) > stereo with no bass ??
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
on the drive home with my 322 I noticed how tinny the stereo sounded , initial thoughts were the settings as the battery had been off but even with it all set to my liking it still lacks anywhere near normal levels of bass , ive found the subwoofer this morning so I presume its not working , so will it be the amp or something else ?
Post #447226 9th Aug 2017 2:36pm
Have you checked the obvious ?
Bass/Treble settings where they should be etc ?
What is the source of the music ? MP3 files often lack bass if not at a high bitrate - have you tried multiple sources ?
After that, it could be the amp or it could be a connection somewhere....
Post #447233 9th Aug 2017 3:13pm
bembo449
ive set the EQ up how I would have it in any other of my cars but its still garbage and nothing like I would expect from such a vehicle pal , im compiling a list of things to look at but numero uno is the suspension , once I get that working correctly then all these little niggles can be attended too
Post #447238 9th Aug 2017 3:20pm
^ can you fill your car profile on please Simon... ... - .- -.
Post #447240 9th Aug 2017 3:23pm
bembo449
I tried yesterday pal , couldn't find an option too ?? will look again in a bit stan
Post #447241 9th Aug 2017 3:24pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
If it's a 2010 to 2012 then it's a common view. I took mine to the dealer as I thought the sub woofer had failed. "They all sound like that" was the response. In fact the woofer is just vibrating but I find only noticeable at head banging volume.
I've stopped turning up the bass as it just deadens the sound. I've got used to the more "refined" sound of the system. It does sound pretty tinny when on the motorway unless you crank up the volume. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #447255 9th Aug 2017 6:04pm
bembo449
its a 52 reg pal but what your saying is the sound system is Censored ! Laughing
Post #447256 9th Aug 2017 6:07pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I've seen the same problem on a 52 plate that was caused by the black DSP amplifier. Changing the amp solved the problem. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #447336 10th Aug 2017 9:16am
bembo449
Ok pal , ive noted the passenger front speaker isnt working either so does the same amp power that too , infact the whole system ??
Post #447354 10th Aug 2017 11:52am
bembo449
Ive been behind to passenger boot panel this aft and there appears to be something missing ?? It sits above the amp and the nav player is above it , any ideas what should be in that space ??
Post #447397 10th Aug 2017 4:55pm
dvd player for the rse pal.. ... - .- -.
Post #447404 10th Aug 2017 5:26pm
bembo449
Ok stan , so will that not effect the sound with it not being a complete system set up ?
Post #447461 11th Aug 2017 7:12am
Rob99
No, as the DVD is only a source and would only have been fitted to cars with RSE. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #447466 11th Aug 2017 8:11am
^ what Rob says.. ... - .- -.
Post #447468 11th Aug 2017 8:24am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
When I lost bass it turned out all four bass speakers in the doors had failed.
Replaced with secondhand units, now all good.
Post #447500 11th Aug 2017 1:11pm
