![]() | Home > In Car Electronics (L322) > stereo with no bass ?? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7977 ![]() ![]() ![]() |
Have you checked the obvious ?
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
ive set the EQ up how I would have it in any other of my cars but its still garbage and nothing like I would expect from such a vehicle pal , im compiling a list of things to look at but numero uno is the suspension , once I get that working correctly then all these little niggles can be attended too |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
^ can you fill your car profile on please Simon... ... - .- -.
I tried yesterday pal , couldn't find an option too ?? will look again in a bit stan |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
If it's a 2010 to 2012 then it's a common view. I took mine to the dealer as I thought the sub woofer had failed. "They all sound like that" was the response. In fact the woofer is just vibrating but I find only noticeable at head banging volume.
its a 52 reg pal but what your saying is the sound system is |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 390 ![]() ![]() ![]() |
I've seen the same problem on a 52 plate that was caused by the black DSP amplifier. Changing the amp solved the problem. Current:
Ok pal , ive noted the passenger front speaker isnt working either so does the same amp power that too , infact the whole system ?? |
Ive been behind to passenger boot panel this aft and there appears to be something missing ?? It sits above the amp and the nav player is above it , any ideas what should be in that space ?? |
dvd player for the rse pal.. ... - .- -.
Ok stan , so will that not effect the sound with it not being a complete system set up ? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1456 ![]() ![]() |
No, as the DVD is only a source and would only have been fitted to cars with RSE. 2021 D350 Fifty Edition - Carpathian Grey
^ what Rob says.. ... - .- -.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
When I lost bass it turned out all four bass speakers in the doors had failed.
