Home > Technical (L322) > 2003 v8 zt 5 speed gearbox issue, only had it a week! |
Gbw321 Member Since: 05 Aug 2017 Location: Witham, essex Posts: 29 |
Hi, I have just got a 2003 v8 4.4 autobiography which I've always wanted, but has started to develop a fault with the gearbox, seemed to start with it holding revs up and not changing up the box correctly, then goes into transmission overheat, and transmission failsafe. Also noticed that the gear select indicator on the instrument cluster keeps disappearing from the display? At other times seems to drive with no issue, especially when from cold. Have read various different articles all saying different things, any advice would be appreciated
6th Aug 2017 10:05pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
If it's driving well from cold I would suspect the oil cooler and rad. |
6th Aug 2017 10:29pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3161 |
Spot on Alistair. Best replace rad and oil cooler for many more miles of happy motoring. |
7th Aug 2017 6:57am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
if you have got transmission overheat a few times now, you need to get the gearbox oil changed at least. as when it overheats the oil degrade much faster then normal.
7th Aug 2017 8:44am |
Is it a big job to replace those?
7th Aug 2017 12:50pm |
Gearbox seems to be getting worse, went out today and it started ok, but the autobox not changing gear and showing Transmission Failsafe in display from start, after a few miles then shows Tranmission Overheat.
8th Aug 2017 6:14pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
id argue its the main reason folk get rid of these machines pal |
8th Aug 2017 6:16pm |
Only just got it, dont want rid of it just yet !
8th Aug 2017 6:25pm |
Find local Land Rover indie and ask there cost for rad and gearbox cooler and gearbox oil change.
8th Aug 2017 6:35pm |
Well car now booked in next Monday with auto box specia so hope not too major. |
9th Aug 2017 10:08pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
was you planning on eating this month ............? |
9th Aug 2017 10:28pm |
Bought it for a very reasonable price, expected to have to pay out on it at some point! |
9th Aug 2017 11:03pm |
I made that mistake too |
9th Aug 2017 11:30pm |
Be sure to let us know the outcome. good luck 2003 Range Rover 4.4 Litre V8 - Adriatic blue 2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html |
10th Aug 2017 7:08am |
