Home > Technical (L322) > 2003 v8 zt 5 speed gearbox issue, only had it a week!
Gbw321
Hi, I have just got a 2003 v8 4.4 autobiography which I've always wanted, but has started to develop a fault with the gearbox, seemed to start with it holding revs up and not changing up the box correctly, then goes into transmission overheat, and transmission failsafe. Also noticed that the gear select indicator on the instrument cluster keeps disappearing from the display? At other times seems to drive with no issue, especially when from cold. Have read various different articles all saying different things, any advice would be appreciated
Thanks in advance..
Post #446889 6th Aug 2017 11:05pm
alistairh
If it's driving well from cold I would suspect the oil cooler and rad.
Post #446891 6th Aug 2017 11:29pm
Dolphinboy
Spot on Alistair. Best replace rad and oil cooler for many more miles of happy motoring.
Post #446911 7th Aug 2017 7:57am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
if you have got transmission overheat a few times now, you need to get the gearbox oil changed at least. as when it overheats the oil degrade much faster then normal.
but the radiator and gearbox cooler should be replaced, common issue. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #446920 7th Aug 2017 9:44am
Gbw321
Is it a big job to replace those?
Front end have to come off?
Any recommendations for place to do it and likely cost? I'm near Yeovil in Somerset.
Post #446932 7th Aug 2017 1:50pm
Gbw321
Gearbox seems to be getting worse, went out today and it started ok, but the autobox not changing gear and showing Transmission Failsafe in display from start, after a few miles then shows Tranmission Overheat.
Need to get it looked at this week i think Sad Not a good start!
Post #447095 8th Aug 2017 7:14pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
id argue its the main reason folk get rid of these machines pal
Post #447097 8th Aug 2017 7:16pm
Gbw321
Only just got it, dont want rid of it just yet !
Anyone know of the likely cost to replace, Radiator, Transmission Cooler and fluids?
Post #447101 8th Aug 2017 7:25pm
b348xyx
Find local Land Rover indie and ask there cost for rad and gearbox cooler and gearbox oil change.
I use http://www.lrsengineering.co.uk and http://www.automatic-gearbox.co.uk for my gearbox.
Really though need to stop driving it with gearbox overheat as you will end up needing a gearbox rebuild and that’s near 2k mark. You really don’t want to damaged the gearbox. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #447104 8th Aug 2017 7:35pm
holidaychicken
From memory you can't change all the fluid in one go without a strip down so I think the correct fluid is around £80, I changed my cooler stat, pipes and cooler( it's not a rad as such as it feeds off the lower section of the main rad to warm cold oil and cool hot oil) which can be another issue as very common is the bottom section of the main rad blocks up and doesn't feed the transmission cooler. I bought my bits from island 4x4 for around £200 I think minus the main rad and fluid. You must use the correct fluid
I would be surprised if genuine overheating is the only issue but RRPhil is your man for taking you down the diagnostic route to find any other underlying cause for the overheat strategy.
As already mentioned , the previous owner knew it was on its way so palmed it off on the next love struck fool to fall for the dirty bit of RR skirt, as I did - but I love her, she is like no other i have ever been in ...., the early RR l323 is a mermaid and will draw you onto the rocks if you let it😬
Post #447153 8th Aug 2017 10:26pm
Gbw321
Well car now booked in next Monday with auto box specia so hope not too major.
Post #447302 9th Aug 2017 11:08pm
holidaychicken
was you planning on eating this month ............?
Post #447305 9th Aug 2017 11:28pm
Gbw321
Bought it for a very reasonable price, expected to have to pay out on it at some point!
Post #447310 10th Aug 2017 12:03am
holidaychicken
I made that mistake too Neutral
Post #447312 10th Aug 2017 12:30am
b348xyx
Be sure to let us know the outcome. Smile good luck 2003 Range Rover 4.4 Litre V8 - Adriatic blue
Post #447321 10th Aug 2017 8:08am
