Home > Technical (L322) > list of faults to do on my nearly aquired 322 |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
just tried to sync the key , I must have done something right as the rear hatch now opens off the remote but oddly the car neither locks or unlocks with it , new key needed ? ive had it apart and all looks ok with the innards |
8th Aug 2017 12:46pm |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Sagging front suspension - in what way, does it drop or not pump up?
8th Aug 2017 5:46pm |
hi pal , the front is in the low position with " susp inactive" on the dash , key to position 1 brings the compressor on , start the car and nothing changes , will get codes read tomorrow , coolant and wash bottle are full yet getting both " low " warning on dash , it had a new battery fitted last night ready for me to collect the car this morning , now its not the biggest battery ive ever seen and I feel its not correct size for the car having owned a good number of large luxury vehicles but it does spin the car over really well
8th Aug 2017 5:53pm |
Hmm it could be a height sensor on the front? As you say hard to see without reading the codes!
8th Aug 2017 6:06pm |
it could wel be pal , see what the codes say in the morning , so many things can go wrong with this set up , I will stick coils on if I have to lol , the key issue is bugging me as ive done the re-code and now the rear hatch pops open as it should but nothing else grrrr , suspension is my main focus , I can put up with dodgy readings for a bit |
8th Aug 2017 6:11pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Does the front suspension get to correct height and then sag or not get there at all?
8th Aug 2017 9:40pm |
it was very low on both fronts pal but not completely on the stops , it is now however since I read and cleared the codes , doh ! |
9th Aug 2017 11:56am |
