Home > Technical (L322) > list of faults to do on my nearly aquired 322
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
ive made a list of things to do while driving to 70 miles back home in the RR ,
sort sagging front suspension
remote not working ( red light flashes )
dash warnings for low coolant & low screen wash ( only came up when 10 miles from home )
good valet & treat the leather
re-secure passenger front door card
sure I will find more things to do when I get a proper chance to look it over
Post #447055 8th Aug 2017 11:59am
bembo449
just tried to sync the key , I must have done something right as the rear hatch now opens off the remote but oddly the car neither locks or unlocks with it , new key needed ? ive had it apart and all looks ok with the innards
Post #447059 8th Aug 2017 12:46pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Sagging front suspension - in what way, does it drop or not pump up?
Key unfortunately I'm not too clued up on, does the lock unlock button Inside the car work OK?
Screens ash & coolant - have you checked the screen wash? Sounds like an easy one... Again check coolant although there is an article in the wiki for replacing the sensor!
I bought my Td6 as you did, with a few little problems... So happy to help where I can. Hate to say it but since having it the original problems where the least of my problems!
Post #447086 8th Aug 2017 5:46pm
bembo449
hi pal , the front is in the low position with " susp inactive" on the dash , key to position 1 brings the compressor on , start the car and nothing changes , will get codes read tomorrow , coolant and wash bottle are full yet getting both " low " warning on dash , it had a new battery fitted last night ready for me to collect the car this morning , now its not the biggest battery ive ever seen and I feel its not correct size for the car having owned a good number of large luxury vehicles but it does spin the car over really well
simon
Post #447088 8th Aug 2017 5:53pm
Stacker
Hmm it could be a height sensor on the front? As you say hard to see without reading the codes!
What battery have you got? If you have got fluid in both at least you know there is no problem with it leaking Wink
Post #447090 8th Aug 2017 6:06pm
bembo449
it could wel be pal , see what the codes say in the morning , so many things can go wrong with this set up , I will stick coils on if I have to lol , the key issue is bugging me as ive done the re-code and now the rear hatch pops open as it should but nothing else grrrr , suspension is my main focus , I can put up with dodgy readings for a bit
Post #447092 8th Aug 2017 6:11pm
holidaychicken
Does the front suspension get to correct height and then sag or not get there at all?
Mine was front air bags leaking.
Could be height sensors , could need calibrating but whatever happens you need good diagnostics
Post #447158 8th Aug 2017 9:40pm
bembo449
it was very low on both fronts pal but not completely on the stops , it is now however since I read and cleared the codes , doh !
Post #447212 9th Aug 2017 11:56am
