Home > Technical (L322) > any must do's for a new L322 owner ( please be serious )
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
just wondering if there are any must do's on an L322 ? im a mechanic so must stuff is do-able and I'd like to start my ownership period on the right foot , prevention is usually cheaper than the cure lol
cheers
simon
Post #446952 7th Aug 2017 3:45pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I'd defo say the oil breather BMW mod... basically rather than the foam type filter, BMW had a filterless design which doesn't get clogged. There are threads about it on this forum but I did it, made a great difference!!
Post #446960 7th Aug 2017 4:11pm
bembo449
ok great pal , thow the seller says it was done when serviced earlier in the year
Post #446962 7th Aug 2017 4:12pm
Stacker
The filter changed or the BMW mod? It would be worth checking anyway as it can cause premature turbo failure!
Post #446964 7th Aug 2017 4:16pm
bembo449
I see , well its had a new turbo also so I guess that might be why
Post #446965 7th Aug 2017 4:17pm
Change all the fluids - gearbox, diff etc Thumbs Up
Post #446990 7th Aug 2017 6:59pm
bembo449
thanks Alistair , I will be towing with it so be a good idea to do the fluids
simon
Post #446992 7th Aug 2017 7:05pm
Complete your profile, so others know what vehicle your have!
Remove plastic covers and check all your brakes pipes .
Post #446998 7th Aug 2017 7:37pm
bembo449
I will when I get him home pal , thanks for that will whip em off for a look see
Post #447001 7th Aug 2017 7:40pm
