![]() | Home > In Car Electronics (L322) > Dash cam install |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Really easy. From an area near the mirror (suggest passenger side tucked in close to the rear view mirror) you'll be able to tuck the cable in behind the roof lining. Then you'll get to the A-pillar which is easy to remove. You'll need a torx driver and the screw is behind the airbag badge. Then the pillar cover will pop off. Run cable down. From there you need to drop it behind the dash. You can use a guide string with a little weight on the end. Then you have a number of options. If your cable is long enough you can run it to a cigarette lighter socket in the centre console. Or run it to the fuse box and fit a simple piggy back fuse connector. None of is is destructive to the RR and you haven't needed to drill a single hole. Re fuse sizes I am sure someone here could calculate but if in doubt with a 1A or 2A and I think you'll be ok. Better to try too small and it'll blow if not big enough! My crude method! Take your time, good luck! Cheers, Greg
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Much thanks GGDR. Great info and appreciated. |
IIRC it is #7 fuse (there, I did in in North American for you |
Thanks, Joe. #7 sounds perfect. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
Craig, there's a dashcam install in the wiki that will explain things.. ... - .- -.
Thanks, Stan. That's fantastic. All done now and I'm quite pleased with it. |
