Home > Technical (L322) > Very strange airbag fault |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2254 |
Evening all right so I have an airbag fault that appeared last week then I had a load of other faults so rolled back the CCF to sort that lot and just for good luck replaced the battery and was left with airbag fault interestingly when I went out and looked in the morning no fault so I have tracked it for a week and if the outside temp as showing on the dash is less than 22 degrees c no fault but above the fault is there and no amount of 11d tool clearing shifts it
25th Jun 2017 8:16pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
There are a couple of other threads concerning the recent warm weather playing havoc with electrics, it could be down to this.
25th Jun 2017 10:16pm |
It is all in the wiki knares
26th Jun 2017 11:13am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 732 |
thanks
26th Jun 2017 1:20pm |
Got to the bottom of it it is the airbag that has failed so will replace |
4th Aug 2017 5:12pm |
New airbag snip at 650 quid plus the fitting fault gone so now on to the next |
11th Aug 2017 4:20pm |
