![]() | Home > Maintenance & Mods (L322) > Supercharger |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
I have a MY 2010 5.0L supercharged and it has developed a slight whine at low revs, I suspect the supercharger as i recently had to have it removed to fix a water leak. As the car has done over 115000 miles I was thinking I might need to give the supercharger a bit of TLC anyway,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
interesting thread here geoff that might help,
Thanks Stan.
you're always welcome geoff.. |
Thanks to both.
Just got back from the Indie, they reckon a new supercharger the bad news is they don't do refurbs or indeed know of anyone locally. The good news is that I should get some change out of £3k to supply and fit a new JLR unit.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Hope they are right if Powerhouse have said it unlikely to be the supercharger. Could be a costly mistake otherwise... Alex
''Ah well you can't take it with you'' cardboard coffin then..
If there are any options I was hoping the forum might come up with 'em. One that springs to mind immediately is that I just put up with the whine - the car is running normally and its not that bad. Geoff |
cant remember if you have changed the oil in your SC, its been done on the 4.2 SC ..
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Stan
a bit off topic but thank you the heads up |
hey you never know when you may need one
I had a whine from mine that was the alternator in the end. How have they come to the conclusion that it is the supercharger?
