Home > Technical (L322) > 4.4 V8 no fuel pressure before cranking. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
if you think that its not getting the pressure up , could it be the fuel pressure regulator thats faulty...
31st Jul 2017 12:07pm |
Siclark Member Since: 05 Jun 2017 Location: Gloucestershire Posts: 40 |
Fitted a brand new fuel filter/regulator at the same time as new Bosch fuel pump. Made no difference to the starting issue. |
31st Jul 2017 12:14pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
If you're not getting any pressure at the valve then it must be a pressure issue surely.
31st Jul 2017 12:40pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Might be worth reading issue I had here.
31st Jul 2017 1:37pm |
What I can't understand is why do I have little or no fuel pressure after switching ignition on ? The fuel pump should prime and provide pressure.
31st Jul 2017 2:44pm |
I found mine was draining fuel back to the tank slowly over time and even when trying to prime car many times it would not. Seemed air locked in fuel system next fuel rail and when trying to start it removes then via the injectors..
31st Jul 2017 4:04pm |
Ok I'm going to search for a fuel pressure gauge and see what's going on. |
31st Jul 2017 7:55pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
It could be an air leak in the fuel system. Maybe refit your fuel filter and give the o-ring a light coat of grease or petroleum jelly before putting the filter back on.
31st Jul 2017 8:14pm |
Been waiting all week for a fuel pressure tester to arrive. Just tried it now to find it doesn't fit the valve on the fuel rail ! The connector on the gauge is too big and none of the adaptors in the kit fit.
4th Aug 2017 12:50pm |
By coincidence I ran completely out of lpg a few days ago and since then it's started from cold perfectly eveytime BUT now I have a hot start issue ! It'll fire straight up with minimal cranking but then dies straight away, won't rev or idle just cuts out. Takes about 10 tries before it'll start and idle.
8th Aug 2017 6:44pm |
What's the battery voltage? ______________________________
8th Aug 2017 8:07pm |
Not sure, can't check it at the moment but it's a recent new battery and also new alternator. |
8th Aug 2017 8:22pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
The fuel rail pressure release valve is a standard schraeder (not sure of spelling) valve the same as a car tyre I believe . Would it be feasible to apply a light pressure with a foot pump or compressor and check for leaks without blowing a seal ?
8th Aug 2017 8:55pm |
