Home > Technical (L322) > Bad vibrations |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35125 |
i'll stab at this and say its the transfer box, hopefully i'm wrong...doesnt sound like the servotronic valve on the steering rack as i have just replaced mine and my symptoms were different [heavy steering].. ... - .- -.
4th Jan 2011 7:09pm |
Could be a number of things based on what you say. Most likely would be burnt autobox fluid and this does cause vibration through the gears and slow changes.
4th Jan 2011 7:21pm |
just found this on another site which 'could' point to the servotronic valve...
4th Jan 2011 7:29pm |
Landrover Mad Member Since: 04 Jan 2011 Location: N.Ireland Posts: 35 |
Hey Max,
4th Jan 2011 11:25pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I had slow take off from cold recently. It would take on occasions up to 8 seconds before I got forward motion. 1st gear Sprag clutch was the issue. Autobox rebuilt before it left me high and dry.
5th Jan 2011 12:48am |
max abbi Member Since: 19 Oct 2010 Location: Newtownabbey Posts: 18 |
Thanks guys for the the replys and pm's. I think I have found the culprit, a sticking drivers side front brake caliper. i knew the front discs were slightly warped and were due for replacement anyway but todayby chance I felt the temp of the front wheels and the drivers side wheel was red hot ! So I have ordered new discs and pads and a new seal kit for the caliper. Will let you know how it goes. |
15th Jan 2011 5:41pm |
I just had a similar problem on the D3 rear offside wheel - it was red hot to the touch and diagnosed as seized piston requiring new piston & seal kit but not disc or pads as these were OK |
16th Jan 2011 12:39am |
SORTED !
20th Jan 2011 7:51pm |
glad my diagnosis was wrong.. |
20th Jan 2011 8:02pm |
Me too |
22nd Jan 2011 3:17pm |
definately me three
22nd Jan 2011 7:42pm |
L7APK Member Since: 14 Jan 2011 Location: Lancashire Posts: 25 |
max abbi was the problem in the end down to the caliper ?
9th May 2011 6:30pm |
Had a similar problem with a rear brake caliper seizing and slowing it down intermittently after a few kms. First thought the worst, gearbox problem but luckily only the caliper or pads as the calipers are fine now. Car had been sitting still for 2 years after import here. Brakes all cleaned and new pads and problem is gone. MY 2010 5.0 SC Galway green and sand interior!!
9th May 2011 6:42pm |
