Home > Technical (L322) > Sticky front caliper
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I'm running a TD6, but has anyone else had this problem?
The passenger side was a failure on the MOT as the tester could hardly turn the wheel, so I replaced the calliper and it's ben fine since but now the drivers side appears to be getting really hot (has been since the MOT)
I stripped it down tonight, replaced the rubber things the sliders go into and cleaned up the sliders as they were pretty tight, pushed back the piston but after putting it all back together, took it for a test drive down the M4 and it's still getting really hot, much hotter than the side i've replaced and the rears.
I'm guessing it's something to do with the piston, its not getting so hot it smokes or anything, but if I was to touch the brake disc I would burn my finger whereas the passenger side doesn't.
Just not sure now, I guess replacement of the calliper would be the best thing?
Post #445635 25th Jul 2017 1:29am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
hi stacker, the pistons do corrode behind the rubber seals. if you go into the wiki on here, i'm sure pete haylands did a strip down, and it should show you how corroded they get.
i've replaced all four of mine, due to the same problem.
Post #445636 25th Jul 2017 4:38am
dingg1
it sounds to me its not braking on the passenger side , you should not be able to touch the disc without burning yourself
Post #445637 25th Jul 2017 4:49am
Stacker
Thanks GregDav Thumbs Up
I'm sure the passenger side is breaking, it does get hot as do the rears but you literally put your hand within 6 inches of the drivers side and you can feel the heat coming off!
Post #445639 25th Jul 2017 5:42am
TomCobbly
Could be moisture in your brake fluid. I had this once on a ford van and it totally locked up the wheel. After using the brakes a few times the fluid expanded with the heat and locked up the wheel. I changed the fluid and all was well. 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #445685 25th Jul 2017 12:18pm
Stacker
Thanks, will have a look.
It's a possibility of changing the fluid when i've sorted the rears out too!
Post #445687 25th Jul 2017 12:26pm
CS
I'd replace the caliper(s). The passenger side would tend to seize first as it's nearer to the side of the road and hence picks up more dirt. On my 2004 car the passenger side seized, with the car shuddering as I drove and then clouds of smoke when I stopped. The problem was with corroded pistons. After a roadside repair the permanent solution was a new calliper.
My experience has been that my calipers need freeing off every annual service, no doubt this is made worse by off road driving and lots of road salt in Scotland, and then replacement after 7/8 years. Only Range Rovers since 1988
Post #445715 25th Jul 2017 3:01pm
I had a front caliper stick, the disc got very hot and had vibration whilst driving.
I decided to replace both front calipers and be done with it. No problems since.
Post #445721 25th Jul 2017 3:12pm
supershuttle
I agree with the other posters on here that touching the disc is not a good idea - it gets too hot. However when My caliper failed in a similar way the wheel got hot and the fuel consumption increased. I replaced one and then the other followed it so I would say replace in pairs if you can. Geoff
Post #445743 25th Jul 2017 5:32pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Has the brakefluid been replaced?Should do it every 2 years!I have also seen that when the rubber brakepipe gets older,that the inside will rot and go soft,resulting in the caliper to stick as the fluid is not flowing freely. 2012 TDV8 Vogue SE 4.4
Post #445758 25th Jul 2017 7:19pm
