Home > Maintenance & Mods (L322) > High Beam Mod
Page 3 of 4 <1234>
Druboo
England 2005 Range Rover Vogue Td6 Zambezi Silver
2005
Have done all the interiors as well and they are fine. Tbh it doesn't bother me Only lasts a couple of seconds
Post #445087 19th Jul 2017 7:26pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
perhaps it has a different can system but Ive not had any issues at all.. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #445091 19th Jul 2017 7:41pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
post pic of how they look in! Smile 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #446294 31st Jul 2017 8:37pm
SamUK
Not a main beam question but, what, if any, are the best replacement dip beam bulbs to buy? I know there xenon but there seems to be quite a choice on eBay?! Mine are useless, all I seem to get is the flicker as soon as you turn them on and then a useless blue/ice/white haze across the road, I much prefer conventional bulbs I must say.
If I jump out of my RR and look at the headlamps they are bright, but where that light is going I have no idea!
Just to add, the lights were aligned on the MOT a few weeks back so no issues there.
Post #446586 3rd Aug 2017 10:30pm
scotcruz
The best ones are Osrams ones. The cheap ones will either flicker or like you say throw the light everywhere.
The thing is the headlamp has the ballast/ignitor built into it otherwise there are some decent Led lamps which would be ace as the light is much crisper.
I would also prefer to upgrade the sidelight rings to proper DRL ones similar to L405 but think I might experiment on some spare ones first.
Horse86 - will take a photo tomorrow and post it. Current:
Past:
Post #446587 3rd Aug 2017 10:39pm
GraemeS
Has someone fitted 6000K HIDs? If so then 4300K are far better.
Post #446594 4th Aug 2017 3:13am
SamUK
Thanks guys, this RR is my first l322 so it's a bit of a learning curve with all these mod cons haha
They may well be 6000k, I haven't checked yet, all I'd done was 'mop' the headlamp lenses to remove all the little scuffs, I do recommend doing so to those who've considered it as it did make a difference.
Post #446596 4th Aug 2017 6:27am
horse86
holding you to it..... Laughing 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #447085 8th Aug 2017 5:45pm
Gbw321
slightly off topic, but not much, i have just brought a 2003 L322 V8 and every time i start the car it says check front fog light, but they are working ok, would it be to the incorrect bulb being fitted? how would i check?
Post #447130 8th Aug 2017 7:45pm
scotcruz
Horse86.. here you go mate.. The photo doesnt do the justice.
Gbw321 the fog lamps take the feed from side lights have you check them? Current:
Past:
Post #447161 8th Aug 2017 10:25pm
SamUK
Lens flare... Stand back and to more of an angle, you'll capture the beam of light better Smile
Post #447176 9th Aug 2017 6:39am
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi,I'm confused,which isn't difficult. My dec 2007 Tdv8 headlamps are xenon but someone mentions they have a shutter mechanism to enable main beam? Why do I have separate main beam lights then that appear a horrid yellow by comparison and seem feeble, presumably halogen h7's? I want rid,should I replace with led or bang in some 100w halogen.Also although I appear to have active swivelling headlamps and cornering lamp fitment in the headlamp unit but i never see any evidence of them working?? Thanks for any forthcoming advice. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #495726 16th Nov 2018 1:59pm
scotcruz
Rapiscan.. I was exactly in the same situation and couldnt understand the point of the additional bulb for high beam when there is a shutter system on the main beam.
Only thing I can think of is the design which mean if the main beam wasnt xenon then the additional bulb was only meant for high beam.
Dont put 100w bulbs they would look horrid. I would go with the Night Life LEDs i fitted Current:
Past:
Post #495728 16th Nov 2018 3:11pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Did they fit without modification?
Could I ask who supplies them?
Thanks AJG BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #495731 16th Nov 2018 3:48pm
scotcruz
Fitted without any modifications.. took 10 mins
Check the first post in this thread.. search on Fleabay think they were £9 Current:
Past:
Post #495734 16th Nov 2018 4:05pm
Page 3 of 4 <1234>
