Home > Maintenance & Mods (L322) > Disaster Oil Change! 4.2 SC
stucart
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Put FF on ramps, removed under trays to allow access to drain plug and filter, got my new oil drainer pan and flexible funnel thingy, raised drain pan on box to make it closer, gingerly unscrewed drain plug by hand after undoing with socket first.............whoosh oil gushes out, dislodges funnel thing, I drop drain plug , it falls into drainer container and blocks hole so Oil overflows, funnel falls to floor ..... 8 litres of Hot oil over me and now on floor.......B*ll*cks! 🙁 What a mess!
What should have been 1/2 hour job too 2 hours and I've had throw away the clothes and trainers I had on , best of all wasn't doing it at home so had drive home sitting on bin bags till could change!
Which idiot positioned drain plug on side of sump!!!!!
All cleaned up now and running sweet on Fuch's Titan Synthetic and K&N oil filter courtesy Opie Oils . Very Happy
Does any one know if there is an 90 degree elbow that could be fitted and drain plug fitted to that so Oil comes out downwards not sideways??
Post #444387 12th Jul 2017 8:51pm
oil's well then Very Happy ... - .- -.
Post #444388 12th Jul 2017 8:53pm
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
you've bin (bagged ) and done it Bow down
Post #444391 12th Jul 2017 9:13pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
exactly my point.. which is why we see more and more examples of garages and users pumping the oil out rather than drain through sump plug which is a bad practice.
With plenty of warning I tried everything to avoid the oil going everywhere but no luck.. Im glad I had a big pan and big card board lying underneath otherwise I would be crying too..
so echo this.. if someone could invent a solution he will be a godfather Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #444409 12th Jul 2017 10:49pm
rkaad
This https://www.fumotooildrainvalve.com/ might help. Have had one on the landcruiser for years...contemplating one for the RR.
Post #444417 13th Jul 2017 12:16am
scotcruz
I like the idea and concernwd that of it faila you could be running the car with no oil. Imagine that.. Id be paranoid all the time.. besides how would these work with RRs as the drain plug is pointing towards the front driver side? Current:
Past:
Post #444419 13th Jul 2017 12:37am
cass
Could use a vacuum pump then if you are worried about what's left in the sump then take the drain plug/s out - there's only a dribble to worry about then
Post #444429 13th Jul 2017 7:41am
TJH1985
We started using a pump now, is so satisfying when you remove the drain plug and only a little trickle comes out!
I wasn't convinced, someone gave us a 8 litre pump and I wouldn't be without it now, it has a float switch so it pumps out 8 and then shuts off so you can empty some out and then carry on.
Post #444441 13th Jul 2017 9:20am
nino_nino
cass is right, vacuum than drain the rest (very little) oil. However if you wanna have real slick solution "if someone could invent a solution he will be a godfather" 4.4TDV8 engine designers have done exactly that. pipe that you disconnect to drain the oil in 4.4TDV8 is the same pipe you use to vacuum extract the oil. this engine does have second drain plug which is used to drain turbo oil pickup pocket-holds about 3~4 dcl oil. i change my oil in 5k km. intervals and drain secondary oil plug every other oil change.
Very Happy Thumbs Up
Post #444450 13th Jul 2017 11:48am
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
any idea which one for FFR TdV8 ? they dont list land rover
Post #444499 13th Jul 2017 7:26pm
scotcruz
I feel nervous with this.. imagine the valve fails and next minute you have a seized engine.. Current:
Past:
Post #444508 13th Jul 2017 9:32pm
stucart
Looks like the Fomoto valve locks so can't come undone, I'd buy one, but as said doesn't list Land Rover.
Surely some UK manufactured thing is available, id be happy with elbow that screws into sump then drain plug into that, anything to get it pointing down!!
Post #444531 14th Jul 2017 8:14am
rkaad
http://www.quickvalve.co.uk/ lists Landrover[/url]
Post #444532 14th Jul 2017 8:22am
scotcruz
Good find mate.. below are the options available. Im thinking we may need an extension but that would further push it towards the frame..
The elbow version is right at the top and the prices are not bad either.. thinking what if upon tightening the elbow doesnt face down then what?
 Current:
Past:
Post #444534 14th Jul 2017 8:31am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
Same situation if a sump plug is not done up properly, but can see where you are coming from as sump plugs are a bit more tried and tested and also the norm.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #444546 14th Jul 2017 10:06am
